Quick chat on engine oil,
Discussion in 'General 1000RR Discussion' started by allbutt55, Aug 21, 2014.
  1. Scott
    Scott Active Member
    Group buy ?
  2. allbutt55
    allbutt55 Member
    That's if I just buy one 4l have to see how many people want one to see if I can get cheaper??
  3. graemewalker
    graemewalker Elite Member
    Hi lo filter hand tight is fine
  4. Scott
    Scott Active Member
    Sweet could we set a new thread up or something
  5. allbutt55
    allbutt55 Member
    I guess so I will ask supplier in the morning see how much I can get them for
  6. Phpbiker
    Phpbiker New Member
    10w40 Silkolene Semi Synth 1400 miles not a drop missing.
    10w30 Castrol 4T Semi Synth 1200 miles not a drop missing ..
    Don't put fully synth in these bikes!
  7. Scott
    Scott Active Member
    I use fully
  8. Garyb
    Garyb Moderator.
    Well, I'm pleased I've just read that.
    Got my oil today and they gave me 10/40 fully synthetic MA2.
    Usually 10/30 semi.
    Did give me a bit of concern at the time.
  9. Scott
    Scott Active Member
    I use 10/30 fully actually. Looking fwd to tryin the silky stuff to see if it's any better gear change cause mine is rubbish
  10. Phpbiker
    Phpbiker New Member
    The answer is in there. Honda spec semi only for a reason. Because its now expensive and they use it in track bikes doesn't make it better in a bike that might get constant speed use for prolonged periods test I've seen show bearing crazing and other hardened surface breakdown with fully synth oils. From the horses mouth effectively. I have no oil loss using 1040 semi silk and the gear change is still like silk
  11. Phpbiker
    Phpbiker New Member
    Hang on...unless that's your track bike blade we are taking about ? Lol
    Still though I asked and Honda still spec semi for all uses.
  12. Scott
    Scott Active Member
    Yea it's a track bike. Not heard what uv said before tho
  13. SimonRR
    SimonRR God Like
    I use fully too, done lots of track and road mileage, no problems either, runs sweet :)
  14. Millsyboy
    Millsyboy New Member
    I always use Castrol 10w40 and seems okay, unless anyone recommends better?
  15. allbutt55
    allbutt55 Member
    Ok I have got a price for the oil :) but who to use for postage?? seem to be getting told around £8-£12 just to post!!!...... any ideas?
  16. Scott
    Scott Active Member
    My hemes ?
  17. allbutt55
    allbutt55 Member
    Ok I can get the 10W40 Comp 4 for £24 each inc, but postage is an issue, so I guess if you wanted to collect?? its cheap most people want £10-£15 just to post???
  18. Mike07
    Mike07 Active Member
    MyHermes.................... Parcel2Go
    £4.40 exc VAT
    But you have to pack etc.
  19. Scott
    Scott Active Member
    I'd be after pro 10/30 if I was to buy some. Sorry for being a pickle
