right guys lets get my handling sorted!!
Discussion in 'Maintenance' started by rocket, Aug 27, 2014.
  1. rocket
    rocket Active Member
    Hi all, Had my 2011 blade since new and barely used as had a tuono as a second bike. I,ve now sold that so the blade is the only toy but i need to get the handling sorted as not happy or confident with it. I,ve never touched the settings from new but it just feels harsh on anything but ultra smooth roads. I know getting it properly sorted is the answer but for now i,d like to try other peoples settings. I,m 15 stone and only do road use. Anyone of similar weight could share there settings to see how it feels. Bike feels to stiff with not a lot of sag at present and i,m running tyres at 32psi front and back. Nearly swapped it in at weekend for a 1050 speed triple but wanna see if i can get it right for me.:cool:
  2. Dave V
    Dave V Elite Member
    I'd personally get it set up by someone that knows what their doing, after all what's it cost £60 at the most?
    32 PSI front and rear, what tyres are you using? I run 32/36 on the road with PR4's
    #2 Dave V, Aug 27, 2014
  3. Garyb
    Garyb Moderator.
    Personally wouldn't touch another persons settings.
    Appreciate they all come out the same factory but the difference can make all the, well difference.
    As said. Few quid getting it sorting out professionally, get the rebound and sag sorted out should give better feed back.
    The fact you say it hasn't been touched since coming from the showroom, I'd say sooner rather than later.
    I'd wager it ain't even standard settings once you take into consideration every oik has had his/her finger nails in the settings screw.
  4. Kevin1
    Kevin1 Elite Member
    Who does set up suspension in the north west?
  5. Millsyboy
    Millsyboy New Member
    If its feeling harsh, need your SAG set correctly for your weight and then compression/rebound
  6. cbrman74
    cbrman74 New Member
    If Leeds is accessible make an appointment with John at Alpha suspension, had mine done yesterday and it's a different bike, only cost £30
    ALPHA SUSPENSION SET-UP - Contact Me / T&C's
  7. rocket
    can anyone recommend a specialist in cornwall /devon as cant find anyone local. dave i,m on the original dunlop qualifiers. had diablo bsb,s on my 07 and that just felt perfect for me. what sort of sag should i have when sat on the bike??
  8. Tug
    Tug Active Member
    peak performance exeter???
  9. N_Collins
    N_Collins Active Member
    I'm going up to these guys in Exeter with mine when I get some time
    Home
  10. Mike07
    Mike07 Active Member
    Mine was very hard when I got it, a bit scary and bouncing around... A set up was transformation
    Mike.
  11. Mike07
    Mike.
  12. Tug
    Tug Active Member
