New HM budget quick shifter
Discussion in 'Mods, Upgrades, Accessories and Products' started by rosier1uk, Aug 1, 2014.
  1. 1000rr73
    1000rr73 Active Member
    Took the blade in to work today and must admit I did this too.... Awesome through the tunnel!
  2. martinowen
    I don't do that
    Much :D
  3. Knxwledge
    Knxwledge New Member
    Thats awesome to hear. How smooth is it shifting under 5k rpm? and what about from 1st to 2nd?
  4. martinowen
    The only one that can shift 1st - 2nd is the GP
  5. ColinBR
    What about the SS? Doesn't that do it?
  6. rosier1uk
    rosier1uk Active Member
    It does shift from 1st to 2nd really depends when you shift if going a bit it's fine. Seems fine under 5k but true enjoyment is when your ringing it's neck
  7. Kentblade
    How much bike did you need to dismantle to fit it matey?
    Thanks
  8. Jimbo Vills
    The plus does mate, but helps being higher up the revs.
  9. rosier1uk
    Tank off top air box and bottom air box I tool tank off as well to give me more room as said it's really just like changing the spark plugs
  10. ozzer76
    ozzer76 Member
    Must admit I was looking recently at purchasing a second hand Plus and it's just been brought to my attention about the lite version. I had a QS on my Daytona and although the sensitivity could be changed I didn't bother as it felt great. Listening to this, I think the lite is the one for me. I'm not after faster lap times, just a smile on my face and a hassle free cheapish solution. The lite sounds perfect for what I want to I think I will be taking the plunge soon.
    As someone who has never actually changed the plugs on a bike, how easy is this? I did fit the last one to my Daytona (Cordona) and it was easy enough. Despite poor illustrations. This blade seems a lot harder to get access to stuff though.
  11. martinowen
    You can change on all of them 1st to 2nd but your not supposed to, the only one that is made too is the GP
  12. lambchops
    lambchops Elite Member
    The first to second shift need a larger kill time due to netrual being in the middle so the only shifter it's safe to do it on is the gp as you can set kill times for each gear on that one... I think you could damage you box over time if you do 1 / 2 shifts regularly on any but the gp.
  13. rosier1uk
    Ozzer just do a search on the forum there are a number of really good threads done by members on fitting a hm quick shifter there all the same fitting
  14. benc
    benc New Member
    Fitted mine over the weekend, so much better than my dynojet one, real nice smooth shift
    I would recommend
  15. Knxwledge
    Can you do 1st to 2nd with the PLUS SS since it has seamless shift technology?
  16. martinowen
    Nope gp only, it's all to do with having a different length kill time for each gear, which is only possible on the gp. All others are changeable but only 1 setting for all gears
  17. Hudson
    Hudson Active Member
    Can i ask..... i have a PC V on my CB1000R, Does the HM fit into their version of this or can the HM fit onto a Dynoject PC V ?
  18. lambchops
    Completely stand alone the hm units Hudson to a power-commander, hm cuts spark not fuelling
  19. arthurbikemad
    CB1000R has traditional coils, you need the HM PC, sensitivity and shift direction is set on the HM PC the kill time and rpm when to limit kill is set in the PCV. :)
    Also CB1000R only has 4 injectors hence why it works ok, 8 injectors not possible with just a PCV. (on most bikes)
  20. Knxwledge
    anyone have a link or a photo of the article of the Fast Bikes September issue regarding HM Quickshifters?
