Cleaning threadlock threads
Discussion in 'Maintenance' started by Barstewardsquad, Sep 11, 2014.
  1. Barstewardsquad
    I use threadlock (Loctite) when I fit/remove mirrors/pillion pegs etc after track days. Cleaning the bolts is easy as I just use a nut, but how can I clean the socket part without using a tap? I don't want to use a tap as I am a bit heavy handed at times and would prefer it if there was some chemical or something I could use.
  2. Mike07
    Mike07 Active Member
    Cellulose Thinners would get a Pikey out of a field....... But be careful what you get it on.
  3. sps170373
    A brass pipe brush will help get most out, like out of an old weapon cleaning kit :)
  4. Barstewardsquad
    Damn, wish I hadn't been so glad to dump the SLR cleaning kit as soon as I could. Don't know any friendly armourers do you?
  5. coupe312
    coupe312 Active Member
    rifle or shotgun cleaning kits are cheap as ... cheap brushes be 3 quid
  6. sps170373
    Will see what I can sort for you ;)
