New boy in trouble
Discussion in 'New Members' started by Boogylite, Sep 13, 2014.
  1. Boogylite
    Boogylite Active Member
    Hi all,
    I have had my blade for about 7 years now, and can't believe how much it still impresses me every time I time it out.
    I have just come back from a trip to Germany, where I took her round the Nurburgring, which was great if a bit scarey. When I came back I decided to change the chain and sprockets as they were past their best.
    All went swimmingly until I started her up and that's when I found out that I had not lined the water pump up as I had to move it to get the front chain cover off, sheering the end of the pump shaft off.:eek:
    I have ordered a replacement pump, but now have a dilemma about the bit of metal floating about in the bottom of the engine. I've tried to fish it out with a magnet but no luck yet, and drained the oil out hoping it might get flushed out.
    Should I drop the sump and get it out - lots of work to move the exhaust etc, or hope that it sits still?
    I think I know the answer but thought I would throw it open for comments or other peoples experience:D
  2. BoroRich
    BoroRich Elite Member
    Is it really worth half-arsing it?
    Drop the sump.
  3. jpsrepsol
    jpsrepsol Active Member
    Welcome and its best to take sump off dont want to risk more costly damage for the sake of few hours saved
  4. Mike07
    Mike07 Active Member
    Try to fish a bit longer and get innovative with the fishing tools, a bit of persistence often works. But if all fails 'If in doubt do the right thing'
    Good luck,
    ,,Mike.
  5. Andy
    Andy Active Member
    No brainer really, Not worth the consequences
    Welcome to the forum btw
  6. sps170373
    Welcome to the forum, I'd drop the sump also as probably better in the long run
  7. RRoss
    RRoss Active Member
    Hi and welcome:)
    I'd take sump off too,key wouldn't be anywhere near ignition until that bit of metal is accounted for.
  8. Jimbo Vills
    I've got a tool which grabs things - also flexible so can get in pretty much most places.... Dunno what it's called but sure this would get it out. Maybe someone knows what it's called? Bet it's not expensive but could save you some time and effort.....
    Looks like this
  9. Barstewardsquad
    +Another for sump off. Risk not worth it.
  10. masterblader
    masterblader Active Member
    Even if the got the broken bit out you need to check the other end being the oil pump if damaged you could end up with an even bigger problem. One cock up is excusable Boogyboy
  11. Frost1
    Frost1 Active Member
    Sump off, need to be sure all bits come out. Welcome and good luck.
  12. Boogylite
    Thanks all for your thoughts - looks like I am in for a bit more work than I first anticipated. I am just going to try one more time at flushing it out/fishing around then it out with the spanners to get the sump off.
    Cheers.
  13. Haggler ®™
    Haggler ®™ Active Member
    Cassete gear cluster ?.....might be easier to pull the gear set out and fish around from there first
  14. BlackDevil
    Hi and welcome!
  15. Boogylite
    Well,
    It was the sump off that did it - even then it was well hidden at the bottom. Just got to put it all back together now. Snapped the exhaust clamp and three manifold studs have come out with the nuts - I just hope that's the end of it.
    A couple of pictures of the mess I have made ...........
  16. sps170373
    It might not seem it right now after a couple of hours work but getting that out will give you peace of mind
  17. Mike07
    I would be spitting chips, but at least you have the skills to sort it. Have a good think before you put it back together, you can maybe do something while its in bits that will save you in time.
    Mike.
  18. Boogylite
    Thanks Mike -I'm going to put the water pump back on before the sump goes on so that I can be sure it's lined up properly this time. I think everything else should be pretty straight forward, I will make sure everything is well lubed up as I noticed that some of the ally bits were showing signs of age and starting to fur slightly.
