Please all shout out your preferred settings please. At mo i have 50% sensitivity, and 60m/s kill time. Whats everyones thoughts. Bike is RR6
Sensitivity is easy to test. Ignition on and watch the HM control unit as you apply pressure to the shift lever. First pressure should not trigger the "shift" light on the unit. Only when you apply the extra pressure that is required to actually change gear should the shift light come on. I have a sensitivity of 85 and kill time of 65 on my 05 Blade.
