08 blade using oil
Discussion in 'Maintenance' started by markie*mark0, Oct 20, 2014.
  1. markie*mark0
    markie*mark0 Active Member
    cheers mate, i've just topped it to about 70% full, so i will keep an eye on it and then will see if it stays are 50%
  2. bonjo
    you are welcome.
    the key is to work out the capacity from min to max marks on the stick. may be slightly different to mine
    worth a try anyway. you will get to know your engine drinking behaviour ;) if any.
  3. Great Guy
    Great Guy Well-Known Member
    I run the bike on paddock stands for 3 mins then cool down for 3 or 4 mins. Then top up to the top mark on dip stick; as it says in the manual. Never had any problems....minimal oil usage... bike now coming up to 25000 miles.
