LUGGAGE RACK for 14 reg Blade
Discussion in 'Maintenance' started by chappo, Nov 11, 2014.
  1. chappo
    chappo Active Member
    Hi, I am looking to get a Rack for my Blade,just wondered which would be the best one to get and where to get it from, any ideas please.
  2. sinewave
  3. Iain
    Iain Active Member
    Ventura is my choice for longer trips away. Or you could try Renntec.
    #3 Iain, Nov 11, 2014
  4. Boo634
    Boo634 New Member
    Hi Chappo I would recommend the Ventura system bit pricey compared to other systems but well worth it don't have a link but I am sure someone will post one Boo
  5. RRoss
    RRoss Active Member
    Renntec rack and Kriega luggage works well together.
  6. Garyb
    Garyb Moderator.
    Yep, renntech & Kriega combination works well for me.
    Especially handy if your moving house ;)
  7. RepsolPaul
    RepsolPaul Well-Known Member
    Used my Ventura luggage system for a tour to Italy, a perfectly made kit.
    Different types of bags n rack to suit all, always some on eBay.
    That and a Givi 307 tank bag recommended from Sinewave.
  8. 1000rr73
    1000rr73 Active Member
    Just a couple of things to note- don't stack up the rear part if the renntec, they quite a 5kg limit. Also, on the 12+ Ventura non abs blade you'll have to file down the painted under panel where the mountings bolt up..... I wasn't prepared to do that as it would notice when the rack was removed.
    I went for a German system that I can't recall the name of, I'll try and dig it out. It was a bit pricy, but it dimply docks in the same was as a rear pillion seat.
  9. chappo
    Thanks to everyone for the response,Kriega luggage looks great, I guess you get what you pay for. Sinewave is that a petrol cap mounted bag,how do you get on with it ? RRoss, is that a Kriega tank bracket you have there? not seen one of those.
  10. sinewave
    Chappo, it's a Givi Tanklock system.
    Piece of piss to use and clips on and un clips in 3 secs flat so refueling is no drama.
    Also keeps the bag 15mm off the tank so paint work scratches either.
    I use the XS 307
    - GIVI Tanklock Bags
  11. chappo
    Thanks 1000rr73, I'd be interested to know the make and where you got it from
  12. chappo
    Sinewave,does it affect you reaching the bars
  13. sinewave
    No, U can adjust it fore and aft to suit ya self.
    Mine was adjusted a bit further back than I would've liked so I could see my Sat Nav clearly, however it was only slightly touching by stomach and was no probs on a weeks touring.
    BTW the so called 5kg weight limit on the Renntec is total Nanny Bollocks and takes far more with no problems.
    At the end of the day it's also a Grab Rail so do U reckon a heavily braked or accelerated Blade with an Adult passenger holding on for dear life is only going to exert just 5kgs of pressure through the Grab Rail? :rolleyes:
  14. 1000rr73
    Here you go, found it....hepco and Becker.
    Hepco & Becker Sportrack - Honda CBR1000RR Fireblade '14-
    I bought it from somewhere in euro land ( and at current rates that'll be favourable for you). I did also get the enlargener plate thinking I could always bolt a top box of something to it. I'm famous for spending money on stuff I never use let alone need and I'm afraid this was another example as I've never toured on the blade yet. The day I need it though it'll be bloody handy!
  15. 1000rr73
    That is a good point on the weight limit, but I think it refers to the rear rack rather than the grab bar parts. I've had a couple of these now and I reckon they'd take a bit more, but the welds on the back ain't that great or substantial. In the photos most folks seem to have the weight on the pillion seat anyway so they'll be just fine. I had a weekend away to Belgium on my old rr8 with a renntec rack and pack and it behaved well enough.
  16. Ian E
    Ian E Active Member
    2014 Non ABS Blade has a black plastic under panel instead, and you can access the subframe bolts, so hopefully won't need modifying.
  17. Ian E
    Ian E Active Member
    I know two people who have had Renntec racks snap - with small top boxes fitted (which they were never designed for)
  18. 1000rr73
    Yeah you do, well at least that's what venturas email told me. I may still have it somewhere. Something about filing out 2 half moons out the painted piece. Probably fine on a black blade, but on my white hrc my OCD wouldn't let me do that.
  19. Ian E
    Ian E Active Member
    Did Venturas email refer to 2014 RR-E model? Mine is 2014 HRC NON ABS. The 2014 don't have the white panel underneath (just a black panel similar to the ABS one).
  20. 1000rr73
    No, at the time I was asking about the 2012. That's interesting, so the 2014 non abs doesn't have this panel painted?:
