  1. Barstewardsquad
    Put Dry Fuel into the wife's NSR and brimmed the tank. Spent ages trying to start it to work it round the system and after 5 mins was about to give up when I remembered the choke :( Things you forget after years of more modern machinery. Once started ran the bike up to temp, then turned off the fuel tap and allowed it to use all the fuel in the pipes so it doesn't clog the carbs over the winter. Finally brimmed the tank for the winter.
    My bike tomorrow :)
  2. Bryan01
    Bryan01 Active Member
    Dry fuel? Tell me more!
  3. Barstewardsquad
    This stuff - Wynn's Dry Fuel
    Idea is it absorbs any water in the fuel. I put it in the tank over winter and not had a problem come the spring. It may be snake oil but it doesn't seem to do any harm if it is :)
  4. Bryan01
    Got ya
    Cheers!
  5. PeterT
    PeterT Active Member
    After fitting some Gilles riser bars and new Venhill brake lines, a Brembo 19RCS master cylinder new Oxford heated grips and a new Honda E-comfort seat had a ride out to West Sussex, talk about a weird feeling as the bike felt nothing like it did before I changed the said items. First was the much improved riding position which was a 100% better than the standard bars, less of an acute angle and only raised by some 10mm, brakes that actually work did not realise how shit the standard master cylinder is, the old one went straight in the bin!!!!!!!
    It now stops on a penny!!
    Comfort seat was lovely too, I thought it would be a gimmick as I ride all year round and cover 16000 miles plus and the standard seat was ok, but boy what a difference the new seat is, I hardly felt the road today and still covered some 125miles on my little trip out.
  6. Slick
    After 20K+ my Tsubaki Sigma chain is proper fecked. 15mm between the slackest and tightest spots. on inspection there was some serious play between some of the links.
    Changed for a Ognibene quiet front sprocket, DID VX Chain and Renthal HA rear. DID was really easy to fit compared to the Tsubaki due to the hollow rivet. Also actually managed to refit the rear wheel without having a hernia!
    Also put some winter boots on (PR4s). Bit scary scrubbing them in in torrential rain but rather that than on my commute
    The blade just feels soo sweeeet :)
    The old Super Sprox and OEM front don't look too worse for wear
  7. madmac
    madmac Well-Known Member
    Covered her up for the winter :(
    She's all tucked in covered in her blanket and under the cover, optimate all connected. Just gotta wait til spring now...
  8. Mr OCD
    Mr OCD Well-Known Member
    Started installing the ventureshield...
  9. Muffking
    Fitted a keyless fuel cap. Not because of some weird race look fettish, but because the track bike came with 2 different keys as the one on the cap didn't match the ignition and I can't be doing with a 2nd key flapping around at speed :eek: So if anyone wants a standard fuel cap with key... ;)
  10. Kentblade
    3 hours to sort out a clutch cut out fault on my NC30, HR joint in the end, I think I must have proved out the same section about 4 times before I nailed it. Wish I would have put the heater on when I started :mad:
  11. Jimbo Vills
    Didn't know you had a NC buddy... Pics please mate ;)
  12. Kentblade
    Unlike yours it's a grey.
    But never left its crate in Japan, so carries a year of manufacturer of 1999, only covered 11K miles and virtually OEM
    • Like Like x 8
  13. sps170373
    That's lovely, guessing it's restricted to 112mph?
  14. graemewalker
    graemewalker Elite Member
    image.jpg we will have to start a nc club
  15. Mr OCD
    Installed new tail tidy after the one on the bike snapped ...
    A bit of polishing, ventureshield and GTechniq EXO to seal the paint.
    Installed wheel graphics ...
    Next step is power commander ...
  16. Kentblade
    Nope, full fat, fitted with MPH clocks from Day 1
  17. sps170373
    Nice, I know a lot of the imports were restricted
  18. Jimbo Vills
    Stunning bike!! Good job you haven't commuted on it ;)
  19. Haggler ®™
    Haggler ®™ Active Member
    Got bored the other week what with all this crap weather and no spare time to ride so decided to have a fettle and have done this.........
    White wheels, number boards and a bit of Rim Tape.
  20. Gilesy
    Gilesy Elite Member
    very nice.. really like that
