HM Plus SS quick shifter
Discussion in 'Mods, Upgrades, Accessories and Products' started by RedMacGregor, Nov 20, 2014.
  1. RedMacGregor
    RedMacGregor Active Member
    Just finished doing the valve clearance check and installing my new quick shifter. No oil leaks so all good so far.
    I just need some base settings for the sensitivity and kill times on the shifter. The bike is only ridden on the road so shifts won't be at maximum revs very often. I think I read something either on the forum or on the HM site regarding a starting point but I can't find it again.
    cheers Steve.
  2. wedgiewolves#223
    wedgiewolves#223 God Like
    65 55 is a good base I think it does tell you s base in the online manual I think
  3. RedMacGregor
    Cheers for that I knew I read it somewhere - those plates still haven't arrived ha ha.
  4. FirebladeRR
    FirebladeRR Active Member
    So is that kill time 65 and sensitivity 55 or vice versa?!
  5. RedMacGregor
    Sensitivity comes first in the menu - called HM today they told me to try Sen 60 Kill 57. The sensitivity is adjusted more to personal preference. I'll have a play over the weekend.
  6. sinewave
    Sensitivity is what you need to get right with the SS as this is not adjusted on the Fly like the Kill time is.
    As long as the Kill time is set to the max you'd ever feel feels nice then the electronics will do it as quick as it can under that time.
  7. kev.b
    kev.b Well-Known Member
    Need to adjust my HM SS on my 06 Blade as had Lurching when changing gear , My settings are Kill 55 , Sen 65 . Not quite right yet .
