Ventureshield ...
Discussion in 'Mods, Upgrades, Accessories and Products' started by Mr OCD, Nov 22, 2014.
  1. Mr OCD
    Mr OCD Well-Known Member
    Any ideas where the 'knee rub' and 'top side fairing' go from this diagram?
    The pieces don't seem to fit anywhere properly lol ...
  2. sinewave
    Fek me you're Brave! :eek:
    Took mine to a 3M specialist for a Pro install, 2 Hrs later and £175 lighter I was on my way!
  3. Iain
    Iain Active Member
    The clues are in the names!
  4. Mr OCD
    You'd think so wouldn't you ... The pieces don't seem to fit where you'd expect them to go...
  5. Mr OCD
    I've done a few kits and fitting is easy ...
    Just got nose cone and the bits I mention to install... Looks pretty good.
  6. Mr OCD
    Tank done
  7. rosier1uk
    rosier1uk Active Member
    I fitted a set to my 09 blade knee rub goes on the top upside of the fairing the bit you see when looking down at fairing sitting on bike and the top side is the at the top of the fairing from just under air intake along and below the knee rub piece hope this helps
  8. Mr OCD
    Any chance you could take a picture for me please?
  9. rosier1uk
    Will do this afternoon ocd when I get back home
  10. Mr OCD
    Thanks... The shape of the film for those areas just doesn't make sense to me!
  11. rosier1uk
    But hard to see on camera but first pic is of the knee rub and second is were the top side goes
    [​IMG][​IMG]
  12. Mr OCD
    You are a legend ... Thank you :)
  13. Mr OCD
    Well the nose cone has me beat... Got the rest done but after two hours called it a day with the nose cone... I thought it would be easy but there are a couple of curves the film simply won't sit right over ... Will get a Pro to sort it.
  14. RepsolPaul
    RepsolPaul Well-Known Member
    If it's the upper parts where the mirror goes, I think by memory you have to give it a pull and stretch it a bit and then push the water/baby shampoo mix out and works then.
  15. Mr OCD
    It's all one part ... the whole nose cone including upper and lower sections. I cannot get it crease free ... I removed it four times to ensure alignment is perfect and even stretching you get creases ... ImageUploadedByTapatalk1416776030.110946.jpg
    Did consider heating the film up to help it bend but the issue is then the adhesive warms up and it quickly becomes difficult to work with...
    I've stuck it back on the backing paper for now .., it's going to need a good soaking in water before its applied again as it's now full of lint! :(
    Did a perfect job of the side fairings too... Lol
  16. Stevie_d
    Stevie_d Senior Member
    Paid a bit more and I left it for the proffesionals
