K&N HIGH-FLOW AIRFILTER ( GBP 25 Delivered )
Discussion in 'Parts, Accessories & Clothing' started by BlackDevil, Nov 6, 2014.
  1. BlackDevil
    I am selling all my Accessories which were installed on my 2011 ABS Repsol Blade.
    17.
    K&N HIGH-FLOW AIRFILTERS
    • Never change another filter! The oil-impregnated cotton fabric of the K&N filter ensures a maintenance-free service life, so all you need to do is occasionally clean and relubricate it.
    • The filter does not need to be cleaned until a 2-3 mm thick layer of dirt has formed on the filter material. This is generally only after 80,000 km of road use.
    • Using a K&N filter can deliver an increase in engine power of up to 5% as well as reduced petrol consumption.
    • Your engine will become more responsive because better airflow allows the fuel and air to be mixed and delivered more quickly. The engine responds more spontaneously when the throttle is opened, and the faster filling of the cylinders is translated into better acceleration.
    • The K&N filter can also often compensate for losses arising from convoluted air intake routes and air filter housings, which usually represent a compromise between available space and efficiency. So you should at least use the best filter available - which means a K&N replacement filter!
    • The K&N permanent air filter is a perfect marriage of racing technology and economy (cleanable and reusable). K&N filters are installed in place of the original filter inserts.
    • They are made from 100% environmentally friendly cotton and are secured in an aluminium grid.
    • When a K&N permanent air filter is used on a standard motorcycle with an original exhaust system and unmodified air filter housings, no modifications usually need to be carried out on carburettors or injection systems. Consequently, the air filter is street legal and does not need to be recorded in the vehicle documents.
    GBP 25 Delivered
    SOLD
    #1 BlackDevil, Nov 6, 2014
  2. marco s
    marco s Active Member
    yes please
  3. marco s
    Payment sent :)
    Thanks Klaus
  4. marco s
    Cheers BlackDevil :) needs a wash tho ;)
  5. BlackDevil
    Yes right, did not have the time to do it ( sorry! ).!
  6. dani90
    dani90 New Member
