Chain Lube Experiment
Discussion in 'General 1000RR Discussion' started by Slick, Nov 23, 2014.
  1. julestys
    julestys Active Member
    Excellent review, thanks for taking the time
    I will buy off this test
    cheers
    J
  2. Slick
  3. Mr OCD
    Mr OCD Well-Known Member
  4. Ramsay
    Ramsay Active Member
    Also use this chain lubricant for my SC36. I am more than satisfied with it. This product covers the chain like a plastic film. No more lubricant at the swing arm. Very good against corrosion.
    But it is expensive and you need the first time a special combination of cleaner and neutralizer to prepare the chain (HKS-R 2 component chain and rim cleaner - Servicing - Technical accessories - Vehicle equipment | Touratech Nederland).
  5. BlackDevil
    I am using that on my Aprilia for the first time, so I don’t have any experience with the product.
    The main reason for me is, that I don’t like grease on the wheel and the bike.
    I used a solid lubrication system ( CarbonForBikes ) on my Fireblade.
    CarbonForBikes
  6. Ramsay
    Ah, ok. Do you have good experience with the solid lubrication system?
    Use 'HKS extrem' for several years and am very happy with it. It's better to clean the chain for the first time with the cleaning agents. Important: Apply 'HKS extrem' sparingly. Better results with little 'HKS extrem'. Then there is no grease on your bike. Warm up the chain before application.
    I use this little applicator
    HKS extrem chain lubricant Applicator 100 ml for use when travelling - Servicing - Technical accessories - Vehicle equipment | Touratech Ltd
    One drop on each chain link. Very good to use on the move. Without rain a chain maintenance is sufficient for 500 to 800 km. When dried, it looks like a very thin plastic film.
    #46 Ramsay, Dec 2, 2014
  7. BlackDevil
    I am using the HKS extreme on my Aprilia for about 3 years and I have to say, that you were absolutely right. !
