Folks I have a new type bazzaz (powered by USB) full boxed setup for the 08 - 15 Blade. Boxed comes with. Full Power Commander, Quickshift and traction control kit. (rrp 625) Autotune kit (rrp 250) Traction control adjust/ map switch. (rrp 110) NEW UNOPENED TC active light. (rrp 85) new would cost near £1100. Looking £625 OVNO
You won't need a tuner to set it up mate. It has a good map on it for a full race system and if you run the auto mapper that maps for you. Any decent dyno tuner can set them up. They are very similar to dynojet power commanders just they don't have the same tuning link so tuning on a rolling road would take longer but with the autotune you don't need that. What's your email for pics or text me and I can text some 07921 849 076
Thanks mate. It's [email protected] Sounds really good. Is it a massive job to fit it all? I'm not too bothered about the TC in guessing I don't have to run it?
I will send you a link to the instructions. The TC can be turned off basically but look at this link. Its a cracker https://www.youtube.com/watch?v=uHwWfAzjdV0. High + numbers is lots of TC. High - numbers means basically no TC. So +5 lots of TC. 0 a little TC -5 no TC. Fitting is about 45 minutes to 1 hour.
