Roller Shutter
Discussion in 'General 1000RR Discussion' started by RepsolSam, Dec 22, 2014.
  1. RepsolSam
    RepsolSam Well-Known Member
    So after 3 years, I decided to put a shutter in my small garage...
    Went on the net and found it..was electric and delivery within 5 days for a custom size..
    After I got it installed..realised, the manual wind down only works from inside the garage..so if the motor fails I'm pretty ******!
    Call up the place I got it from, they said I never requested for a manual external override..! @ £120!!
    How stupid for a electric garage not to have a manual over ride on the outside..
    How am I meant to open it when and if the motor fails?
    #1 RepsolSam, Dec 22, 2014
  2. Haggler ®™
    Haggler ®™ Active Member
    That's one hell of a small garage !
  3. Jimbo Vills
    Normally you'd have a rear entrance door you can acces from the garden etc into the garage to get to it, if not you'd get the override....
    Can't you access your garage from the other side of the alley? ;)
    Ps - in London where space is a fecker. That's an awesome idea to secure the bike mate
  4. RepsolSam
    Lol...its 1.2M wide and the length of the house...I call it a garage..my wife calls its a alley..has brick on either side, back and a proper roof...so garage right
  5. Jimbo Vills
    Think your wife might be right dude lol
  6. kpone
    Yeah my new one's the same as Jimbo says the door company said I didn't need an external over ride because I had the back door.
  7. RepsolSam
    Nope no rear entrance..
  8. BoroRich
    BoroRich Elite Member
    What you need to do is knock out the bricks at the other end of the garage and put another shutter in there. No need to get the manual override because you'll have two :D
  9. Mike07
    Mike07 Active Member
    Is it a direct drive from a gearbox or chain with sprocket reduction. Anyway the one I had, had a shear pin in case it got stuck. maybe you could try to pull it out and see if you can lift the door by hand if the drive is disconnected, and someone crawl in. If that works a wire to the house from the pin (through the wall) in emergency pull the pin.
    Mike.
  10. sinewave
    I have an idea Sam! :)
    #10 sinewave, Dec 22, 2014
  11. RepsolSam
    Maybe..
    #11 RepsolSam, Dec 22, 2014
  12. sinewave
    That is what I assumed Sam. ;)
    #12 sinewave, Dec 22, 2014
  13. RepsolSam
    thanks
    #13 RepsolSam, Dec 22, 2014
  14. RepsolSam
    Ah man....lol
  15. madfish2001
    madfish2001 Active Member
    You may want to think about getting the holes (left and right) blocked off to make it more secure. A trolley jack in there would have your door off in seconds.
  16. RepsolSam
    Thats sorted....:cool:
