Can I fit a speedo from a 13 plate blade to my 09 plate blade? If yes is it a straight swap? How much would a second hand speedo cost? Thanks
Yes you can fit the later speedo, you will also need the later front sub loom probably looking around £350-450 for all of it
Yes the gear indicator on the +12 year blade dash does not work when installed on the previous model. All the other functions work though.
