Hi all, as my new blade will be mostly tracked I want to remove ign and fuel cap. I want to remove completely so can I buy and fit a USA ecu and then simply remove and rewire ign thru a kill switch. Last thing i want is to arrive at a eurotd and find ive left the key at home.
I didnt a similar thing to mine added American ECU, just make sure its not from the emission heavy californian spec bike! You should be able to just add a simple switch to the ignition wires or wire it via the kill switch I guess thats possible.. Im doing the same to mine but as its a road bike adding keyless ignition so using a transponder to turn it on.
