Easy bleed on Brembos
Discussion in 'Mods, Upgrades, Accessories and Products' started by Barstewardsquad, Jan 15, 2015.
  1. Barstewardsquad
    Have given in and got a set of Brembo M4 (aka blink) for the bike. I'm thinking of putting some easy bleed nipples on them and wondered if they are any good, or just a waste of time?
  2. sps170373
    Sounds like a good idea but haven't used them sorry, I've got a mityvac hydraulic pump which is good for bleeding brakes
    Mityvac Brake Bleed Kit
  3. Slick
    I've got some (though on OEM calipers) easy peasy!
  4. chrisopotamus
    chrisopotamus Member
    Are the hoses are very snug fit on the nipple or kind of loose? I bought a knock kit of a mityvac and the hose is a touch too big.
  5. wedgiewolves#223
    wedgiewolves#223 God Like
    I have always used a pipe in bottle and bled away done my bike from dry front and rear in 20 mins . Just start with master then right caliper then left never had the need to use a bleeder or speedy nipples lol :D
  6. sps170373
    Mine came with a set of different adapters for different nipples so had no problems
  7. Barstewardsquad
    Ahh but this simply mean you don't have to open and close the bleed valve for each lever press, and besides your 20 mins will take me hours ;)
    Right I'm going to get some once I know the right size to get. Next decision is if I go for the Stahlbus at £20+ each, or the Goodyear at under £10 each.
  8. Bryan01
    Bryan01 Active Member
    Man Up and do it the old fashioned way! think of the quality time in the man cave! Just done mine and I'm :)
  9. Barstewardsquad
    LOL you have no idea of the amount of faith that I have in my ability to mess up all things mechanical, so I like the things which make my life simpler :)
  10. sps170373
    What's the difference between the two makes? Is one stainless and other plated mild steel?
  11. Slick
    the Stahlbus's are much more advanced
    see diagram, the cheaper ones you still need to loosen at the caliper thread, risk of wear, xthreading etc. Stahlbus uses a separate thread to bleed
    Stahlbus
    Goodyear
    That said I have the goodyears, never looked back!
  12. arthurbikemad
    Never use them, Brembo's are easy to bleed, they will even bleed themselves if you leave the bleeder open long enough. Just don't forget to bleed the master!
  13. wedgiewolves#223
    Ha ha ok buddy let us know how they shape up
  14. chrisopotamus
    I've read this a few times but wow I had time getting them going when I put on the M4's the other day. I was wondering what the hell was going on because I was going at it for a good 20 mins before I could get anywhere.
    Replaced lines etc many times over the years and never had it take so long to get them started.
  15. Barstewardsquad
    Well I contacted Brembo to confirm the required sizes etc, asked Arthur but he wasn't sure, but he was of course right ;)
    Here is their response:
    To be honest, I would not recommend these in place of the bleed nipple, they are questionable as they are ask for thread length and I am also worried that the taper angle on the seating area may not be correct.
    Our bleed nipples are M10x1. Thread length is 8mm
    Based on that and Arthur's advice I guess I am best going to the chemist to get a MTFU pill and use the supplied kit.
  16. Bryan01
    I found that once the Brembo MC was bleed the M4 were really easy. If the MC is bleed and you can feel pressure on the lever M4's are straight forward.
  17. chrisopotamus
    I did the MC first like I always do but couldnt get any pressure on the bar for ages. Don't know why but eventually got it.
