Traction Control
Discussion in 'Mods, Upgrades, Accessories and Products' started by l3nny, Jan 23, 2015.
  1. l3nny
    l3nny Member
    After highsiding my 929 I said I'd never get another 1000cc bike unless it had TC fitted. However the lure of the Blade was too much and I chose a 13 model over the BMW or Kawasaki, unfortunately as you all know TC isn't an option.
    Does anyone have any experience with fitting an aftermarket Traction Control unit? Are they any good? How much did it cost?
    I will only be riding on the road with the occasional bimble in the novices so don't need a race worthy system, juse looking for a bit more safety.
    Cheers.
    #1 l3nny, Jan 23, 2015
  2. N1xxl
    N1xxl Member
    IRC prob the most reasonably priced aftermarket system and it uses wheel sensor and easily fitted and has many race features available to build on.
  3. sinewave
  4. Mad Matt
    Traction Control is for little girls, i stripped the TC from my zx10 and give it to charity;)
    • Like Like x 7
  5. N2OCapri
    N2OCapri Active Member
    I have recently fitted a GripOne P3 unit with IMU, not tried it yet but after a lot of head scratching it seemed to do what I wanted.
  6. Scott
    Scott Active Member
    There's quite a few people wanting tc. Shame ant get a group buy with someone decent and an English company
  7. RRoss
    RRoss Active Member
    Wonder how HM are getting along with the Traction Control feature of the GP Quickshifter:rolleyes:
  8. Scott
    Scott Active Member
    That would be nice
  9. l3nny
    l3nny Member
    Thanks for the replies, the guys who are saying you don't need traction control are probably much better riders than me. Multiple broken bones and a written off 929 would suggest my throttle control could do with a little electronic assitance.
    Shame there are no decent road based systems about that don't cost the earth.
    The Gripone looks okay but buying from a foreign company I've never heard of worries me a little bit, £400 is about what I wanted to spend as well, £1500 seems a little steep as I'd never use any of the race stuff. N20Capri, let me know how you get on with it. :)
    #9 l3nny, Jan 24, 2015
  10. Blade048
    Blade048 Active Member
    +1
  11. MadG
    MadG New Member
    Badly setup TC is probably more likely to result in a high side than having none, and getting off on the low side is generally less painful.
  12. l3nny
    l3nny Member
    How so?
  13. robbo
    robbo Active Member
    does bazaaz do a stand alone tc ?
  14. BlackDevil
  15. MadG
    MadG New Member
    Because if it isn't setup properly and cuts the power violently then inertia will take it's course and you'll end up doing an impression of superman when the tyre regains grip.
    My opinion is if you want TC get a bike that has it as standard as it will have been developed and setup for it.
    Aftermarket systems need a lot of input and skill to setup properly.
  16. Scott
    Scott Active Member
    Not what I hear about irc. Heard it works well out the box
  17. l3nny
    l3nny Member
    I see, makes sense, you're probably right with regard to buying a bike with it from factory, I've never had great experiences with aftermarket stuff and I'm not great with a spanner, even worse with a soldering iron.
    I've read only negative things about the Bazzaz system, the fuel map and QS would be good for me but mainly want TC.
  18. sinewave
    Best sell the Blade then and get one of these!
  19. l3nny
    l3nny Member
    Have you had a runny nose all over your bike? ;)
  20. robbo
    robbo Active Member
    Thats a link to jhs racing, I'm booked in with them next month for the bazaaz with Q Shift and 'Traction'
