Chain Cleaner - Any thoughts?
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolSam, Feb 5, 2015.
  1. RepsolSam
    RepsolSam Well-Known Member
  2. Adrian7886
    Adrian7886 New Member
  3. Slick
    paraffin and old tooth brush followed by water based greaser then proper chain cleaner and rags
    Easy peasy
  4. Remal
    As above paraffin and old tooth brush or rag and then dry and re apply Wurth dry chain lube.
    Also used other types of chain cleaners and they don't work as well but good heads up
  5. BoroRich
    BoroRich Elite Member
    Looks like an unnecessarily complicated POS :D
    Paraffin rag and a little bit of elbow grease with the bike up on a rear paddock stand and bob's your uncle. Easiest way I know to clean a chain.
  6. Barstewardsquad
    One of these with some form of chain cleaning fluid and some rags.
  7. Blackness
    Blackness Active Member
    WD40 on a rag brings the gold links up real nice and easy !
  8. kev.b
    kev.b Well-Known Member
    Yep WD 40 is best !
  9. thefirebloke
    thefirebloke Elite Member
  10. robbo
    robbo Active Member
    I bought a can of chain and brake cleaner only half thinking it would work, it stripped the chain of all that shite with no effort at all just the spray of the aerosol, looked new and in 2 mins was dry as an arabs dap ready for some new wax, think it was wurth.
