rear wheel bearing kit cbr 1000 rr4
Discussion in 'Maintenance' started by daz1, Feb 15, 2015.
  1. daz1
    daz1 Active Member
    how many bearings in the cbr1000 I had a set del and it as five bearings in it two dust seals took the wheel off and can only found 4 1 in either side of the wheel itself and two on the driven flange
  2. Muffking
    I thought that there were 2 bearings + seals in the wheel and then 2 in the sprocket carrier. Not sure what the 5th bearing is doing there?
  3. daz1
    daz1 Active Member
    yes mate im a little baffled myself
  4. t0m541
    t0m541 Senior Member
    Is the fifth bearing an odd size or does it match any of the others ??
    It may be they just put an extra one in by mistake...possibly.. :)
  5. Blackness
    Blackness Active Member
    I got an All Balls set and had the same confusion too dude as i ended up with a spare that doesn't go anywhere either !
    My fifth one is now a paper weight ;)
  6. daz1
    daz1 Active Member
    got mine from same place mate
