Battery conditioner/optimiser
Discussion in 'General 1000RR Discussion' started by Sam, Feb 23, 2015.
  1. Sam
    Sam New Member
    I used a optimiser all through the winter to keep my battery in check, I don't really use it during the summer months but a chap I know uses one all year round, what do you guys do?
  2. Barstewardsquad
    Mine sits on a solar charger all year round. I will occasionally give it a week on a trickle charger if it has sat for ages and the weather has been cold/dull.
  3. RRoss
    RRoss Active Member
    If it's gonna be sitting for more than a few days unused then it goes on the optimiser.
  4. sp1n99
    sp1n99 Active Member
    When my bikes are in the garage they on plugged in to an Optimate at all times.
    I had a Tuono for six years (being a big twin they are hard on batteries) but never had any problems whatsoever.
  5. Kentblade
    As above mate, my bike is used daily but nearly every night it is on a Optimate, apart from the previous Blades ABS ECU flattening the battery (that one is in my NC30 now, as I did not realise what had caused the issue and bought a new one, which went flat the next week), I don't have problems or buy new batteries, in fact my 929 was on 95K when I sold it and on the original battery.
  6. Lozzy
    I use mine daily too but don't use charger, are you saying it helps lengthen battery life? Any other benefits?
  7. madmac
    madmac Well-Known Member
    Mine is connected to the Optimate all the time I'm not riding it. Did the same with my previous bike (CBR600F) and that was 8 years old when I sold it and still on it's original battery :)
  8. racman
    racman Active Member
    It surely does
  9. Si.
    Will they revive a totally flat battery??? mines been sat outside all winter, and is flat as a fluke.
  10. Sam
    Sam New Member
    Sounds like most people use them all year round, and as for bringing a dead battery back it will to a certain extent but it'll never be like a new battery and I wouldn't have much trust in it
  11. Kris
    Kris Active Member
    I use mine all year around and have never had to buy a new battery.
  12. Wurzel45
    Wurzel45 Active Member
    Lead acid battery's will suffer if not kept topped up, if left to discharge too much or for to long rarely will they recover.
    Remember these are small battery's unlike the one in your car which has spare capacity, my advice would be to trickle charge as often as you can regardless of how often the bike is used as the battery will naturally loose its ability to hold max charge the older it gets due to the chemical process, that being said some modern Chargers will have a de scale cycle to help refresh the battery to some degree. Lithium:D
  13. bash1k
    bash1k Active Member
    Could I ask what solar trickle charger you use? I'm looking for one now and any recommendations / advice / experience with them would be great
  14. Barstewardsquad
  15. bash1k
  16. Adrenalinrush
    Adrenalinrush New Member
    I just bought the Optimate 6 and it says in the book that it needs to be reading a minimum of 2v to be able to bring it back, I looked this up when I had a battery showing only .02 v, in which case the only response from the optimate was to show the power on light.
  17. Cbrjay
    Cbrjay Well-Known Member
  18. Dave
    Dave Member
  19. Alaska
    Alaska New Member
    Me too, plugged in all year round, no probs.
    read a report about old optimisers goin on fire, manufactures recommend replace after a period, me had no probs over last five years
  20. Shutty
    Shutty Well-Known Member
    Just bought my bike yesterday and it's on the optimate tonight, found it had connections for a charger from previous owner, which explains why it's 7yrs old and original battery
