calipers discs and brake and clutch master cylinders with gold levers job lot
Discussion in 'Parts, Accessories & Clothing' started by daz1, Mar 1, 2015.
  1. daz1
    daz1 Active Member
    front calipers and brake and clutch master cylinders with gold levers job lot offers invited pict to follow for a cbr 1000 rr4/5 the clutch is not shown as still on bike but does come with job lot same lever as brake discs are about 5mm sellint due to brembo upgrade discs have gone to muffking so the rest £100 posted
    #1 daz1, Mar 1, 2015
  2. daz1
    daz1 Active Member
    nobody want them evilbay it is then
  3. Muffking
    I reckon you'll get more if you split them.
    Just out of interest though, how much would you want for the discs?
  4. daz1
    daz1 Active Member
    make me an offer mate
  5. daz1
    daz1 Active Member
  6. Muffking
    lol, I'm terrible at that as I never know where the line sits between a good deal and an insulting offer :D
    In the mean time I need to find out how easy they are to swap between them and the 320mm RR6/7 discs as they're for the wets on my RR6 and I don't know if you just remove the calliper spacers or if there are some kind of inserts available like on the RR4/5?
  7. daz1
    daz1 Active Member
    I think its the case of just removing the cal spacers but don't quote me on that as for the discs price you can have them for £50 posted if you want
  8. Muffking
    Cheers. Do you remember seeing any collars fitted in the fork bottoms to seat the callipers on to when you removed them? They would be really handy to have with the discs so the callipers stand no chance of moving.
    Either way I'll have the discs if you're happy at that. PM me your details and I'll sort the payment out later.
  9. daz1
    daz1 Active Member
    I think the bottem of your forks are the same as the rr4/5 so Honda made spacers for the rr6/7 to acomadate the bigger disc I think your calipers are the same as mine as no spacers on the rr4/5 did you get my pm if not how do i send a pm with this new site
    #9 daz1, Mar 2, 2015
  10. Muffking
    lol, I'm having the same issue with PM's. It's down as Conversation, although I'll paste your username into Conversations so it goes just to you as your message ended up on my Profile Wall. Don't worry though, I deleted it :)
    Re the collars, the fork bottoms are the same, but the RR4/5 has collars to seat the calliper on to, rather than spacers on the RR6/7. Did you remove the collars when you changed your calipers?
  11. daz1
    daz1 Active Member
    the collers are not removable they are part of the bottom of forks as far as I can tell the brembo m4 I have put on fit straight on
  12. Muffking
    No worries there. I'll measure them when the wheels are next off and buy some online as I've got to swap my tyres over anyway.
  13. daz1
    daz1 Active Member
    thanks mate snowed under with work at the moment 7am till 7 pm I live for the weekends lol
  14. daz1
    daz1 Active Member
    IMG_1335.JPG discs and disc bolts will be on way tomorrow garry
