  1. hondahead1000
    hondahead1000 New Member
  2. Mickydove
    Mickydove Active Member
    Yep and a bit of elbow grease,I had to have a lay down afterwards :D
  3. Mr OCD
    Mr OCD Well-Known Member
    Liking that ... I need to sort my downpipes as they look bloody scruffy! - cheap stainless steel!
  4. hondahead1000
    Lol , worth it but m8, saw your post and thought thats a super job so nows the time as i have side fairings removed changing all the fluids and giving front side of engine a good degrease, waiting for rad guard to come as well to tidy up adiator as well as protect it but my pipes look badly browned so best get at them lol
  5. Philhasasti
    Philhasasti Active Member
    I put it into honda for its 8000 mile service, mot and new tyres. It's all set for the summer..
  6. hondahead1000
    Looks great m8, shinning like a dogs b***s, rad guard did u mean u fitted at 8000miles
  7. Mickydove
    Haha! Sounds like you've got a busy weekend ahead;) don't forget to put some pics up after:D
  8. hondahead1000
    I will mickydove before and after mate
  9. hondahead1000
    Seeing the job u done got me motivated, have go and try and earn a pound or 2 now lol , talk soon
  10. Barstewardsquad
    Modded the main beam HID same as I did the dipped yesterday. Fairings back on, just the screen left to do. Put some rubber sheath around the rear brake hose, probably going to run with it as it is until I get dosh sorted for a new one.
  11. Muffking
    Took the road Blade for it's MOT this morning which free'd up space to get the track bike out for some work before Snett next weekend.
    Spot the difference (BoroRich should get this) ;)
    Before
    After
  12. martinowen
    Res hanger gone
  13. Muffking
    Got it in one :D
    Done both, which is a job mentioned in Rich's post about the HRC rear brake reservoir post. Done it to the road bike too, but this one has no exhaust cover either, so that hangar's gone too.
  14. FirebladeRR
    FirebladeRR Active Member
    What did you cut with or do you recommend cutting them off with?
  15. Muffking
    Just an angle grinder with a 3mm cutting wheel. Then smoothed it down with the grinder and painted over it in black.
  16. Barstewardsquad
    The angle of the charger connector is different too ;)
  17. Bryan01
    Bryan01 Active Member
    image.jpg image.jpg Finished fitting Brembo rear HPK and Hel brake line
    #4997 Bryan01, Mar 7, 2015
  18. Muffking
  19. Mickydove
    Crash bungs fitted,just waiting for carbon belly pan and rear hugger image.jpg
  20. GappySmeg
    GappySmeg Well-Known Member
    Lifted tank, removed airbox and intake duct. Then removed the following:
    Also check the spark plugs whilst I was in there... all looking good!
    Obtained a mint condition air duct from a scrappers, so I can set about removing the flapper from mine, and some general "adjustments" with a stanley, 1mm polyprop sheeting, and super glue!!!
