Fitting grips?
Discussion in 'General 1000RR Discussion' started by BoroRich, Mar 20, 2015.
  1. BoroRich
    BoroRich Elite Member
    Anyone got any tips for fitting them. I've done a couple of pairs in the past but always end up wrestling with them and end up with glue all over the bloody place :D
    I have heard of using hairspray? Anyone tried this??
  2. Barstewardsquad
    Removing - Long thin screwdriver under existing grips and spray WD40 underneath them as you rotate the slide the screwdriver around the throttle body.
    Fitting - As said hairspray is great as it lubes whilst fitting but dries tacky. Personally I have never used the supplied superglue.
    If you fit the datatool ones make sure you remove all the old glue from the plastic throttle body or they won't go on
  3. BoroRich
    Ahh right. I've always just cut the old ones off with a stanley.
    I'm fitting the Renthal Dual Compound ones.
  4. scooby
    scooby Elite Member
    if you have an air compreser it's very very easy.just stick the nozzle underneath the grip and blow air in,they just slip off,then put them on same way and secure with some lock wire
  5. BoroRich
    I saw that trick. Unfortunately I don't have an air compressor. Wish I did!!
  6. Mr OCD
    Mr OCD Well-Known Member
    I use a grip spray ... it's clear and thin so no mess...
    Spray into grip, then slip it on the clip-on ... 30 second job. :)
  7. Tom68
    Tom68 Active Member
    I used hairspray on the last pair, Had no problems with them yet, Been on now for 2 years. :)
    We used to do the same on the 250 Kwak MX bike that we used to race.
  8. madmac
    madmac Well-Known Member
    Go on. Try the hairspray. Because you're worth it.... ;)
  9. graemewalker
    graemewalker Elite Member
    Hair spray make sure it's loreal for that blond moment
  10. rebel
    rebel Active Member
    I put some on the other week hairspray works a treat 2015-03-05 09.59.29.jpg
  11. BlackDevil
  12. Moon
    Moon Active Member
    Just done mine today, it was a doddle. Hardest part was getting bar ends off, I think I used to much loctite when I put them on
  13. StanleyRR
    StanleyRR New Member
    Never used anything on renthals. Stick the grips in boiling hot water for a minute or two then twist them on. When they cool they dont move a mm. Easy on.
