Brakes not what they should be
Discussion in 'General 1000RR Discussion' started by restone, Mar 25, 2015.
  1. restone
    restone Active Member
    After fitting new goodridge stainless lines and new fluid, cleaning the disks and scouring the pads the brakes are a little less sharp and the lever is travelling back too far under real sharp breaking.
    I thouroughly bled 1st the far caliper then the near then the master and repeated no leaks either.
    Do folks think its worth rebleeding now after riding a couple of hundred miles could the vibration have released some of the stubborn trapped air
  2. GappySmeg
    GappySmeg Well-Known Member
    Have you tried tying the lever back and leaving overnight?
  3. Barstewardsquad
    Can't hurt to give it a quick bleed after a check for any seepage. Also try tieing the lever back to the bar overnight, just use a cable tie or similar.
  4. exuptoy
    exuptoy Elite Member
    +1 for the tying the lever back to the bar overnight. Been there before and the best way to bleed these is either reverse bleed with a large syringe and force it back to the master or get a plastic tube and leave it submerged in a tub of fluid then pump the lever plenty of times then tie it back overnight. That will cure it.
  5. restone
    Ok so I normally bleed with clear plastic pipe on bleed nipple submerged in a jar of fluid.
    With the tying back the lever method
    Do i do it with the above attatched and the bleed nipple open
    and is it best done on the master, far or near caliper.
    many thanks
  6. exuptoy
    No fella, the reason for tying it back is that any trapped air with flow back up the open line back to the header tank.
  7. sps170373
    I always bleed master then calipers, +1 one for tying lever back over night
  8. GappySmeg
    No mate... you do a full, normal bleed exactly as you have done.
    Then, once you've got it as good as you can, tie the lever back to the bar using cable ties, shut the garage, and open the booze.
    Come back the next morning, remove cable ties. You should feel a noticably firmer lever, as the last remnants of trapped air have been allowed to move up into the reservoir.
  9. Slick
    It's good practice to leave the lines under pressure for a bit, better chance of detecting any leaks
    While the lever is strapped I like to periodically tap the lines too, gives those last pesky bubbles a extra hand to rise up to the reservoir.
    You guys leave the res cap on or off when strapping down the lever?
  10. exuptoy
    On is fine.
  11. Barstewardsquad
    +1 for leaving the cap on.
  12. Slick
  13. restone
    many thanks folks, did the bleed then strapped back the lever for 24hr fired her up to give some vibration and gently tapped the lines and calipers with rubber hammer. The lever feels way firmer. Just wish the twats from the council would stop gritting so I could get out and test her properly.
