I'm after a front wheel for a 06 fireblade. Need one to put wets on. I've just got a rear, so only after the front ideally with discs on. And obviously in good condition. Not sure wether different year blades fit the 04-07's. Cheers, James.
Ditto Haggler. I would like to know what other parts you have especially if you have a radiator and fairing panels.
All the bits I have are from my RR7, I have owned it from new, so can guarantee it has never been in an accident!, or even dropped! It had about 8K on the clock, always garaged, Honda serviced, and in immaculate condition, when I started changing lots of bits for after-market replacements, (not because they were faulty, looking tacky, or anything like that) to bling it up a bit. It is my project bike now, so sorry no panels or major bits like engine etc., the bits I have for sale: a. Both standard black Wheels c/w (still fitted) Michelin Pilot Power Pure, (Approx. 800mls normal road use on the tyres), brake discs from new, standard gearing rear talon gold sprocket (approx. 500mls normal road use on sprocket) b. Standard gearing steel rear sprocket, approx. 500mls use. c. Front shock inserts, original from new d. Complete rear shock, original from new. e. Original chain guard. f. Original rear hugger. g. Original rear tail/number plate holder c/w plate light, and indicators etc. h. Original front indicators. i. Original under seat exhaust end can, (the paddle valve is damaged, so would either need a new one or be fitted without it working) j. Original brake & clutch levers. k. Original screen (but has very slight/small mark that is hardly noticeable, but had to mention) l. Original front foot rests, heel plates, foot brake pedal, gear linkages etc. m. Original tyres, Pirelli Corsa (done Approx. 600mls, but they have been sat/covered in my garage for 7 years, they still seem ok, and may be ok for track use, but not sure about road use) Think that's about it.
