Misfire
Discussion in 'Maintenance' started by Mad taffy, Apr 8, 2015.
  1. Mad taffy
    Mad taffy New Member
    Hi guys need some help my rr4 blade was parked up over winter changed the plugs oil disconnected flapper mod now I have a bad misfire at low revs but go when you open the throttle should I put the old plugs back in .
  2. Cbrjay
    Cbrjay Well-Known Member
    Has the fuel gone off?
    Try swapping plugs, are plug gaps ok any damage to ht leads?
  3. racman
    racman Active Member
    there r no ht leads. coil per plug set up
  4. Mad taffy
    Just put old plugs back in and it's running fine my dad always said if its not Broken don't fix it.
  5. Dave
    Dave Member
    What make plugs are you using, we have had terrible trouble with NGK's. Have had no problem with Nippon Denso's.
  6. Mad taffy
    NGK mate bought them from m&p phoning them tomorrow.
