NEED A NEW ECU 2007
Discussion in 'General 1000RR Discussion' started by Martyn1966, Apr 11, 2015.
  1. Martyn1966
    Martyn1966 New Member
    Hi
    I wont bore you with the reasons why, but I need a new ecu. Can anyone advise if I have to get an exact code match ecu or will any 2004 to 2007 ecu be ok?
    Martyn
  2. dave d
    dave d Elite Member
    Have you tried to reset it? Start her up don't touch the throttle wait for fans to kick in then kill switch
  3. Barstewardsquad
    +1 for the above, but disconnect the battery for 10 mins first.
  4. Muffking
    06/07 will be ok, not sure about 04/05 as they're mounted differently. Also, you would need to change the key/lock if the edu can't be programmed to your existing key?
    Where abouts are you as I have an RR6 track bike that you could swap bits with.
  5. Martyn1966
    Hi
    I've basically snapped the casing on the ecu. It works but I have to tape it up, which I don't want to do. I'm in Bolton, Lancashire, so any help would be much appreciated.
    Martyn
  6. Barstewardsquad
    Silicon sealant would probably be better than tape for now.
  7. Muffking
    If it's just the casing then would you be in a position to swap just the casing with any RR6/7 ECU off ebay or similar? Should be much easier than changing to another ecu and having to swap other stuff over to match.
  8. Martyn1966
    It's broke where the wiring connector locks onto the ecu, so it basically wont lock in place. It's a real pain. I know it's all hidden but I know it's not right and I just want to keep the bike a good as possible!
    It sounds like I need to get another ecu and lock? If so how much should I pay?
