Gilles gear shift shaft holder
Discussion in 'Mods, Upgrades, Accessories and Products' started by Simon_HRC, Apr 24, 2015.
  1. Simon_HRC
    Simon_HRC Active Member
    Has anyone used these or recommend them?
    I have ordered it as sometimes the gear shift doesn't feel great, a friend of mine has got a GSXR750 K7 and his gear rod snapped the shaft!
    Since then I've been paranoid haha plus the standard one that's on there doesn't even do anything.
  2. GappySmeg
    GappySmeg Well-Known Member
    They seem to be a forum favourite... loads of us have got them.
    I found it made the changes more positive and eliminated false neutrals from clumsy-footed changes... I wouldn't be without one!
  3. sps170373
    Worth the money! I didn't realise how much they made a difference till I put one on and tried it, positive gear changes every time
  4. Simon_HRC
    Thanks guys :) glad I ordered it now haha
    I do find sometimes there are clumsy gear changes at slow speeds so hopefully this will be as good as you make out!
  5. Gilesy
    Gilesy Elite Member
    you won't "feel" the difference as such.. but will be just solid changes as you originally expected.. I've had one for years.
  6. RRoss
    RRoss Active Member
    The bottom pic shows a 'modified' bolt holding the shift rod onto the shaft and it also seems to be sitting further out. Does the splined shaft not have a recess which prevents the shift rod coming off if the bolt slackens? Sitting this far out will it sit right on the splines with bolt in place?
    Or is this just a generic picture and it fits like it's supposed to on the blade.
  7. Repsol Rob
    Repsol Rob Elite Member
    Kept getting false neutrals while doing track days...... not had one since fitting the above.......... well worth it
  8. charger
    charger Active Member
    That's part of gilles rearsets or shifter kit, it sits a little farther out than OEM part. Oem part fits normally.
  9. RRoss
    RRoss Active Member
    Anyone got a photo with the shaft support fitted on a blade?
    I've got an HM GP fitted and I'm sure someone here said it gives nice changes with the 2 together :)
  10. Barstewardsquad
    As said they are the dog's danglies, and one of those things that really should come fitted as standard.
  11. ray
    ray Well-Known Member
    2007 Blade
  12. RRoss
    RRoss Active Member
    Think I'll have to add one to the list:D
