SP Ohlins recall?
Discussion in 'General 1000RR Discussion' started by martinowen, Apr 25, 2015.
  1. martinowen
    I just heard there may be a recall on SPs 14 and 15 due to faulty Ohlins
    Not sure if it's true or not but if you own one I would get it checked
  2. sinewave
  3. martinowen
  4. bob
    bob Active Member
    Just tried find my numbers and looks like shock might have to come out or check! Will get bike out of garage and have a proper look later!
  5. bob
    bob Active Member
    Just phoned my honda dealer and they weren't to helpful didn't even know about recall and can't look at the bike until 15th of May!
  6. sinewave
    Just been down to the Garage and got my numbers, typed em in and got a "Your TTX is not effected" message!
    If anyone gets an invalid Part Number message make sure you've only typed in the first 3 numbers after the YA KA etc bit, the last number although on the shock is not required and causes an 'invalid' message if inputted.
    Happy Days! :D
    #7 sinewave, Apr 25, 2015
  7. bob
    bob Active Member
    Sinewave did you manage to see the numbers with the shock on the bike?
  8. Ritchierich
    Ritchierich Elite Member
    No Martin it was gravel in middle of road and I've done 2 track days on the SP since with the shock holding out but going to check numbers just looks like I'll have to remove it to see them :-(
  9. sinewave
    Yes Bob you can see the numbers whilst the shock is on the Bike, they are a tadge small though and you'll need a small LED Torch or sumat to help make them out.
    God knows why they print them that size, there is room for bigger numbers.
  10. bob
    bob Active Member
    I tried and failed yesterday even using a small mirror will try again today!
  11. sps170373
    The numbers are also on the box if you purchased new and still have the box, no help for the sp owners I'm afraid though
  12. bob
    bob Active Member
    Spoke to honda dealer today again and he said there's no recall from honda so I'm ok to ride it buddy!
  13. Cbrjay
    Cbrjay Well-Known Member
    A nut may loosen, and your bike may crash
    Love that part
  14. Cbrjay
  15. graemewalker
    graemewalker Elite Member
    When it reaches European you will get a letter off visa for recall it can take months ,prob most dealers not aware yet until you enlighten them,as said its to do with a slack bolt. Checked mine but can't see any numbers on top prob have to remove shock ,I will wait until I get letter off the wobbles vosa
  16. graemewalker
    Binoculars springs to mind,I will try and get a new shock out of them and sell origional cheap or I will cancel my rcv v4
  17. bob
    bob Active Member
    just spoken to honda care and they are going to investigate. I emailed them the link to the ohlins site which shows not to ride and how my dealer said it was ok as honda hadn't issued a recall and asked who would be liable in event of a crash due possible suspension failure and could I have it in writingbwhich they declined until they have investigated.i also told them that yamaha have issued a recall on r1ms with the senshock fitted? Hope it isn't going to be a similar situation to c-abs
  18. bob
    bob Active Member
    Honda have called back this morning and said a recall is imminent but it has to go through vosa first and did not say exactly how long imminent was?
  19. Barstewardsquad
    If it is anything like as long as rich had to wait for his sp ohlin's forks from honda it will be a very very long wait.
