fuel display error
Discussion in 'Maintenance' started by magma, May 29, 2015.
  1. magma
    magma Active Member
    I turned the bike on the other day, the fuel level warning light was on, the milometer was flashing, as it does when the fuel level is critically low, yet I still had around a gallon and a half in the tank. The light would not go out until I filled the tank, just wondered if anyone has a fault like this?
  2. Iain
    Iain Active Member
    That's what happens when the fuel is low. It's not a fault!
  3. Kentblade
    There's your problem buddy, the world as moved on, you have confused your bike by filling it with gallons, it was designed for litre petrol.
  4. magma
    magma Active Member
    Jeez here's me thinking I've got a fault... really you think I'm daft the fuel warning does not come on when there's sufficient fuel. The warning light comes on only when you are down to about 2 litres. I thought perhaps a sensible answer from an educated forum would ensue. Doh..
  5. pete954
    pete954 Active Member
    Irony.........
  6. Barstewardsquad
    1.5 gallons is actually 6.8 litres and so I doubt it should be triggering the low fuel warning. Question is how sure are you of the amount of fuel in the tank?
    PS A gentle bit of mickey taking/humour is only to be expected. If this site was just facts it would be boring ;)
  7. Great Guy
    Great Guy Well-Known Member
    Just ignore the light then and run out of fuel. The bike is a heavy lump to push. Lol
  8. Kentblade
    If you want to get techy, then without fail my fuel warning comes on at 12.8 litres or in your money, 2.8 Imperial gallons.
    The quoted tank size is 17.7l or 3.88 Imp galls, but I have put in just over 18 before, so at 5.3l or 1.16 Imp galls is about the right calculation for my 2104 with the tank brimmed.
    So if you have a Imp gallon and a half (assuming you guessed this, rather than drained and measured it) , that's around 6.84l, but if you are an American cousin then that would be 5.7l to your smaller gallon and half or 6 quarts as they say, so we ain't a million miles (or 1609344 kms) away are we?
    Hope that clears any frippery up.
    #8 Kentblade, May 30, 2015
