Power commander 5 for 08 cbr1000rr
Discussion in 'Mods, Upgrades, Accessories and Products' started by Chem600, Dec 19, 2011.
  1. Chem600
    Chem600 Active Member
    Hi guy, I am about to order the above but have been doing some searching and am now not sure whats best :confused: Can you guys confirm if the 09-10 cb1000r (4 injector connector and 1 tps) pc5 fits the cbr1000rr 08-? I am under the impression it is the better option as it takes its tps reading right from the tps like the old pc111 and not from the main harness like the cbr1000rr pc5 does (2 injector connectors and tps connector into main harness)
  2. CastrolCraig
    CastrolCraig Active Member
    PC5 is fine to use on 08. Arthur is the man for this sort of stuff and i myself was the first person to run a PC5 on an 08 in the country, on my old boys old race bike.
  3. JM1
    JM1 Active Member
    Check 1000rr.net for info on this....
    Memory is hazy on this, but I thought the Americans didn't like to use the cbr model as it uses up the conector they need for the IRC module (their bikes are restricted), so they use the cb model instead.
    The PCV on my 08 is a cbr model but only has 2 connectors & 1 tps.
  4. zeepony
    zeepony Active Member
    I've got a PCV i'm going to sell if your interested - was going on ebay but im lazy and i dont have time to sort it out! PM me if you want it.
  5. Si.
    Can I have second dibs on this if the price is right? I'm going to put on a yoshi can, and if it doesn't run right, then I'll go the pcv route.
  6. zeepony
    Of course, its actually been set up with a Yoshi slip so i'll leave the map on there if you like. I'll give OP a day or so to read this and see if he wants it - otherwise PM me laterz.
  7. Villan
    Villan Active Member
    You bugger.....I've had a post in the wanted section for weeks.......Grrrrr
  8. zeepony
    Sorry chaps, like i said - i'm lazy and dont look in there!
    If there are a few people that want it, i guess the fairest thing to do is post it in the For Sale section? I have other bits like ASV levers which i'm going to sell so keep an eye in there. I just need to make sure all the parts are together and its not missing anything.
    Sorry OP for hijacking the thread a bit..
  9. dan.1moore1
    Mine may be for sale soon but a member has already reserved it
    I'll post it up if they change they're mind
  10. Chem600
    Well this is an interesting forum, answers and possible sales in the one thread :cool: So I am ok to use either pc5's as we don't need the IRC.
    zeepony I will PM you now about the PC5 as long as I am not stepping on anyone's toes??
  11. JM1
    JM1 Active Member
    Yes, just make sure you use a cbr map if you choose to fit a cb PCV!
