Clutch problem
Discussion in 'Maintenance' started by maluczczi, Jul 26, 2015.
  1. maluczczi
    maluczczi Active Member
    Hi Guys
    I went for a ride yesterday - it was everything fine and never had any clutch problem before - but on my way back home - i spotted my clutch is slipping. It was all right up till 7-8k and then started to slip.
    I was still riding toward home and spotted that 'clutch slipping border'' through 6k,5k,4k,3k,went down up till 2k.
    I used to have a rule if something is wrong with engine i don't touch it.
    But I hope it's maybe some minor thing which i could do myself?
    Any suggestions please ?
    thanks
  2. dansp1
    dansp1 Active Member
    Cable or hydraulic clutch?
  3. RRoss
    RRoss Active Member
    Replacing clutch plates easy enough if you're fairly confident with a spanner and can follow instructions. I used to think it was like black magic until I grabbed a Haynes manual and changed the clutch on my bandit years ago.
  4. Cbrjay
    Cbrjay Well-Known Member
    What's the oil like? When was it last changed?
  5. maluczczi
    Oil just been changed 3 weeks ago mate. Its cable clutch but i checked it and its all fine.
    It feels like some bolt have undone ?? Is that possible ?
  6. Cbrjay
    I had clutch slip problem on a 600 after changing the oil, was ok after done a few miles on it
  7. RRoss
    RRoss Active Member
    How old is the bike and how many miles? Stupid question maybe but I take it you used a quality motorcycle oil from a reputable retailer? Only time I've had clutch slip is when the clutch was worn out:(
  8. PeterT
    PeterT Active Member
    Clutch plates should last at least 40K plus if not abused on a blade, sounds like you have used some dodgy oil
  9. maluczczi
    Bike is 2011 4500miles I used Motul 7100.
    Ive done around 500 miles on this oil before it happend.
  10. dansp1
    How much play do you have at the clutch lever?
  11. maluczczi
    maybe 0.5cm
  12. dansp1
    Sounds like you need to strip your clutch
  13. RRoss
    RRoss Active Member
    If it's genuine motul oil you've used then that's very unlikely to be the cause of the problem. Clutch lever seems to be adjusted fine. Has the bike been changing gear ok?
    As said above I think the clutch will need to be stripped to check for worn/warped plates or broken spring.
  14. maluczczi
    Yes never had any issues with nothing at all.
    I always imaging if clutch go - it's longer process. That's why I thought maybe something unscrewed or something?!?
  15. rb1000rr
    rb1000rr Active Member
    Not being a Motul user is the oil you used fully or semi synthetic have heard a few stories of slipping clutches on fully synthetic especially on low mileage bikes just a thought
  16. maluczczi
    Full synthetic mate. I dont know what was before but was fine.
  17. rb1000rr
    Its possible then fully might sound daft lubricates to well and on a low mileage engine and can stop the normal wearing in process read somewhere wasnt advisable until after 12k miles although fully or semi is a can of worms subject like tyres lol have run mine on semi from new now done 36k miles road track long journeys etc with no probs hope you sort it mate
  18. Dave
    Dave Member
    Shouldn't be any problem with the engine oil, sometimes if you use a car engine oil this can cause clutch slip due to the slipping additives in car oil. Pull the clutch cover off and check the clutch plates, its not that difficult a job probably 1.5 hours. You will need a micrometer or vernier caliper to measure the plates though.
  19. bonjo
    It could be the slipper clutch playing up. Motul 7100 is a very good oil for bikes so don't worry on that front
    Have you had your local Honda dealer look at it yet?
  20. maluczczi
    I know it's good oil I have always use it before in my previous bikes and always been happy with.
    I'll try to fix my own first - i let you know what was the reason.
    #20 maluczczi, Aug 3, 2015
