can anyone help
Discussion in 'General 1000RR Discussion' started by Mark123.7276, Jul 29, 2015.
  1. Mark123.7276
    Mark123.7276 New Member
    Thank you
  2. Mark123.7276
    Just see this . Is the the fuel pump and shouldn't there be wires on it
  3. Muffking
    Not sure what to make of that photo other than that your exhaust servo is in a weird place?
    Where a bouts are you BTW?
  4. Mark123.7276
    Chessington Surrey. I started the bike again this time I ran a bit longer then revs went up then died again
  5. Mark123.7276
    this is so weird just took all the fairings off moved a thew wires about and now it seems to be running ok
  6. Muffking
    Too far from me, but again make sure that the pump primes every time you turn on the ignition. May also be worth checking that the due line under the tank isn't trapped. But if it turns out to be wiring, then it also worth trying to narrow down to which wires you wiggled to get it to work.
  7. Mark123.7276
    Will do . Thank you for your help
