One fan not working
Discussion in 'Maintenance' started by Pinkster1000RR, Aug 15, 2015.
  1. Pinkster1000RR
    Pinkster1000RR Active Member
    Hi peeps,
    I have a 2011 HRC blade and i recently noticed that one of the two cooling fans is not working when the temp gets too 104 degrees....
    Has anyone else had this issue?
    I assume that they are both on the same fuse??
    Jay
  2. Slick
    IIRC the smaller left fan should not kick in until 108c.
  3. Pinkster1000RR
    Well i never knew that.... Just checking now
  4. Pinkster1000RR
    Yep all sorted.. comes on at 107 degrees
  5. Moon
    Moon Active Member
    When I bought mine new I took it back as I thought one was broken lol
  6. bonjo
    on RR8 the fisrt fan kicks in at 105, the second at 108@109. I expect your to be the same
  7. Pinkster1000RR
    Well all sorted, i removed the relay for the RH fan so that the bike would get hot enough for th e LHS fan to kick in...and it did at 107 so all happy, as i'm off to Portimao again in October
