Brakes ...
Discussion in 'General 1000RR Discussion' started by Mr OCD, Aug 17, 2015.
  1. Mr OCD
    Mr OCD Well-Known Member
    Just sorting the blade out ready for Donnington after doing Pembrey recently.
    Noticed the brakes grab the disc at same point when spin the wheel on the stand... You can hear it as well.
    What's that about then? Getting fed up with these brakes on this bike! :(
  2. Nickw
    Nickw Active Member
    disc probs either got a warp, but 1st option is to try and free off the floating things... Can't think of the name of the damned bit. Come on, someone help me out...
    Anyway, I ride in all weathers and the floating things (haha) often get crudded up. I put a nut and bolt through, tighten it up and then turn it with a socket while spraying copious amounts of brake cleaner on to it until it frees up. Often works and it allows the disc to float again... And... it's worth a try before sticking micrometer on it to check that disc not warped...
  3. Mr OCD
    Discs are spotless (washed every week) ... No warp either... It's like the pads are moving in the caliper ...
  4. barry107
    barry107 Active Member
    They are called disc bobbins :)
  5. Nickw
    Nickw Active Member
    Thank you... Well, try freeing off those disc bobbins :D:D
  6. Mr OCD
    I'll check them for sure ... Will be popping calipers off anyway for a quick check.
  7. Barstewardsquad
    Youtube vid on checking and cleaning the doobery flips
  8. Nickw
    Nickw Active Member
    Yep, that's the things I meant, and that's what I do every now and then as part of cleaning. Don't be shy squirting brake cleaner on. It might just cure it for you... There again...
  9. exuptoy
    exuptoy Elite Member
    Scott, give them an extra chance by forcing out the pistons when you have the calipers off and cleaning them with a toothbrush and brake cleaner then push them back once more after coating them in Castrol red rubber grease.
  10. Mr OCD
    They were cleaned up just before track day... didn't use red grease mind, as don't like the mess :D (OCD lol)
  11. Mr OCD
    Popped the bike back on stands today ... And errr it no longer does it ...
    WTF!!!
  12. Nickw
    Nickw Active Member
    That's the beauty of a Fireblade see... You look at them and they fix themselves...:D
    Bizarre...
  13. Mr OCD
    Maybe it's because I gave it a good wash and wax after being abused on track and road for the last few weeks! :D
  14. allbutt55
    allbutt55 Member
    Will have to give this a try and at the end of brands hatch I had bad vibrations coming through the handle bars :( pads and discs have only about 2k miles
