clutch cover cbr1000rr4 help please
Discussion in 'Maintenance' started by daz1, Aug 22, 2015.
  1. daz1
    daz1 Active Member
    hi all is there a technique to putting the clutcth cover back on ive just put a stm slipper clutch on and having a bitch of a job trying to get the clutch cover back on
  2. Haggler ®™
    Haggler ®™ Active Member
    Yep......The problem being the alignment of the starter shaft. Try moving the cover 5 mm forward before it comes into contact with the dowls or get a mate with a torch and screwdriver to guide the shaft into the cover
  3. daz1
    daz1 Active Member
    top man thanks did what you said worked a treat thank again your a life saver
