Bridgestone , Michellin , or Metzeler
Discussion in 'Mods, Upgrades, Accessories and Products' started by Stevie_d, Apr 12, 2015.
  1. Remal
    Currently running my first set of Metz M7RR's and well impressed. Most of the rear tyre used withing 40 miles from new running 36F 38R and feel good, lots of grip. Unsure on the tyre life as it's my first set of Metz but i'm putting them up against the Dunlop Sportsmarts I loved. If they are as good or better then Metz will have lots of my money in the future
  2. SteB
    SteB Member
    I had PP3s put on mine and rode it home from Demon Tweeks to wigan in the rain, even new they had grip and feel. When I've been caught out in the rain the feel is so good I can light the back wheel up and powerslide it on demand. As the weathers warming up they're just getting better and better.
    You've gotta run factory pressure though or it feels very squirmy. Took mine out in January, pressure was fine in garage (heated to 18 degrees), went to meet a couple of our sales guys for a coffee because the sun was out, temperature was 3 degrees and it was dark when I set off back home....could feel the tires moving immediately.
  3. ccr32
    ccr32 Active Member
  4. Emywmpb
    Emywmpb Active Member
    I'm not sure on your type of riding, but if you stay off the track on the bike I have to recommend Pirelli Angel GT's. They aren't pure sports tyres, rather sports-tourers, but every review reveals that their performance is not only right up there with pure sports tyres in both wet and dry, but the toughened central profile will give significantly more road miles without squaring off. Plus, the tread pattern looks really cool!!!!
  5. maluczczi
    maluczczi Active Member
    I had S20 Evo. I liked tyres but they really gone fast. I've done less then 2000 on back tyre. Not heaving them any more.
  6. Simon_HRC
    Simon_HRC Active Member
    Ordered the Metzelers today :) will let you know how I get on
  7. Mr OCD
    Mr OCD Well-Known Member
    Done 4k on the M7RR so far ... Nearly on limiter ... Great tyres imho.
  8. neilfb
    neilfb New Member
  9. Simon_HRC
    I have ordered the 55 profile as well as a lot of people on here have said its better for change of direction etc. we will see :)
  10. Stevie_d
    Stevie_d Senior Member
    Just had pilot power 3's fitted today . All in at £235 , glad I went to Honda as there's an ecu update just came out for my bike for better fuelling etc. bike seems lots smoother low down @ 2-3k
  11. DF!
    DF! New Member
    Just dropped mine down for new rubber tonight. Going for pp 1ct front and rear. Did the rear of my set of Oem s20's in 1700 miles.:rolleyes: Hopefully PP's will last for 2000. ;)
    Had a screw in the rear for the last hundred miles or so. Pulled it out and pressure stayed up, looked bad though as it cut a 150mm groove in the tread where the screw had been pushed round under acceleration.
    Anyone got thoughts on speed rating. PP's are W rated 169 mph I think. Blade will pull 185... This worries me a bit. I do have a couple of long quiet straights on my way to work, if you know what I mean.
  12. SteB
    SteB Member
    I've had my bike up to 170mph on the PP3s and they were fine. Not too many places you want to be that kind of speed on the public highway though ;)
    Get caught at that speed and your tyres will be the least of your worries. :p
    BTW, the PP3s have 2CT+, which means the hard compound runs underneath the soft compound to keep the tyre more stable during lean acceleration.
