Gear indicator
Discussion in 'Mods, Upgrades, Accessories and Products' started by Still at it, Sep 11, 2015.
  1. Still at it
    Still at it Member
    Found someone selling these on eBay plug and play where on the 05 blade does it plug in
    Any help would be great
  2. Muffking
    Depends on the brand. Accumen plugs inline with the clocks. GI-Pro plugs into the red diagnostic port behind the left upper fairing.
  3. Still at it
    Still at it Member
    Thanks for the help I've not got one yet just looking for the easiest one to fit
  4. Still at it
    Still at it Member
    Going for the gi pro looks like the thing I'm after
  5. Nytol
    Nytol Active Member
    I'm very happy with mine.
  6. Still at it
    Still at it Member
    Was it easy to fit
  7. Greco
    Greco Active Member
    Gi pro are the best out there with good reviews. I fitted mine a few months back so pretty straight forward job. Instructions were clear too. Do a search on this forum and good luck. Oh, and red is the most visible on all weathers.
  8. Nytol
    Nytol Active Member
    I got the bike shop to do it while they were doing some other bits for me, but they didn't say it was any kind of issue, and normally they would if it had been.
  9. Great Guy
    Great Guy Well-Known Member
    I have put the red one on. Dead easy to fit.
  10. Still at it
    Still at it Member
    Do you have to take any off the fairing off?
  11. Great Guy
    No. Just the petrol tank cover, so that you can run the cable through to the plug in thing near the battery. Put the bike on paddock stands so you can change gear ; this will set the synchronise the unit to the gears.
  12. Still at it
    Still at it Member
    Thanks will order one now
  13. sulaco
    sulaco Active Member
    If you use the GI-Pro on a 2005, you need to take the left(as you sit on the bike) middle faring off. Really easy job took me about 15 mins from start to finish.
  14. Still at it
    Still at it Member
    And this is where I will find the plug I'm looking for ?
  15. sulaco
    Yeah will be a red plug with a cap on it (sometimes covered with black tape for some reason), plugs straight in. I fitted my display on the left side of the instrument cluster with the supplied Velcro stuff, zip tied the wire to the fairing stay, and along the clutch cable till it disappeared into the fairing, connected the plug and tidied up the remaining cable. Job done
  16. Still at it
    Still at it Member
    Thanks this should be here early this week thanks for the help and thanks to all
  17. Barstewardsquad
    As said 05-07 is behind left hand fairing by the fuses. 08+ is under the seat.
  18. tony lomas
    tony lomas Member
    Hi fitted a gipro last week took 20 minutes took off the tank cover fed the wire to the diagostic port next to the battery .when fitting make sure you turn your handle bars lock to lock easy to fit works great should have fitted one years ago
  19. Jandy
    Jandy Active Member
    Ok guys how easy to fit on a 59 plate :oops:
  20. Still at it
    Still at it Member
    Gi pro turned up today will fit this tomoz once again thanks for the help
