Hi, i'm selling my beauty, new project in mind ..... Engine : - all refresh less than 6000 miles, all parts new : bearings, rings, oil pump, cam chain and tensioner, clutch, HRC gasket - gearbox like new with 3th gear NOVA RACING ( preventive ) - New cylinder block - HC piston Wiseco 13,5:1 - cylinder head bought new with new valves, tuned by KWS in USA - stock cams with personal cam timing ( from HRC dept ) - air filter SprinFilter - stacks from a 2014 SP bike ( same as HRC kit - ARATA full titanium system with AKRAPOVIC carbon can from an RSV4 - flashed and tuned OEM ecu on dyno - samco hoses - all fluids new and service ok Frame and suspension : - 2013 shock bought new, around 4000 miles since -2010 fork with OHLINS NIX30 kit inside less than 4000 miles, 1kg springs in it + 2x 0,9 + 1x 0,950 springs - OEM cart kit available - NEW chain kit with 525 Ek 3D chain + RS7 ( best of the world ) sprocket , actually in 15/43 but 16/42 in rs7 too available - full GB Racing -rearset Gilles Tooling VCR, with carbon pads - Gilles tooling chain adjuster + Titanium nuts - screen from a 2014 SP bike - tank gripTech Spec - diabolo - Gilles gear set - black epoxy passing rear set - Evotech plate support - custom led + signals rear light - wheels PVM black modèle racing 2014 - Schifter Translogic intellishift Brakes : - Full beringer : front + rear calipers, low location with brembo relocation / brake+ clutch MC - front rotors like new - rear rotor GALFER - Goodridge lines - HRC rear brake kit 2012 fairing personnel painting + HRC tank cover paint too with tech spec grip too few parts parts available , stock, engine , akrapovic, etc. few other parts like Ti nuts, bolt etc. thinking about selling the complete package but if the big parts find new owner ( brakes / engine / wheels / fork, etc ) can thinking about breaking it. Full package at 8200£
If i split it, is someone interested in : full built an refresh engine 1400 PVM wheels 2015 version + brake disc 850 fork with Ohlins 30mm kit less than 2500 miles 750 Arata full system 600 Beringer complete kit 900 Translogic intellishift schifter 250 Full fairing + hrc tank cover 600 2013 shock 160 all prices shipped excluding the engine.
