Gearing
Discussion in 'Mods, Upgrades, Accessories and Products' started by exfire, Dec 24, 2011.
  1. exfire
    exfire Elite Member
    I would be interested to find out what gearing changes people make to their Blade for road use. I believe the 2oo6 to 2008 bikes run standard on 16 front 42 rear and the 04 to 05 on 16 F 41 R.
    I would like a bit more acceleration, yep I know I will lose some top end but that doesn't bother me too much. I am sure some of the 'track' guys can be a lot of help on this one.
    I always face the same dilemma, whether to lose teeth on the front or add them onto the rear or a bit of both.
    I have been on here Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
    Some advice on the pros and cons of each option would be good, also how much of a difference it makes to acceleration in reality.
    Cheers and happy Xmas eve
  2. dan.1moore1
    Im running -1 front
    Plenty for me .. Front lifts easier . My mate has -1 front + 2 rear but that is way to much IMO
  3. CastrolCraig
    CastrolCraig Active Member
    i ran -1 front +1 rear. i have a gearing chart somewhere, ill dig it out.
  4. megawatt
    megawatt Well-Known Member
    -1 front, +2 rear for awesome acceleration and float front wheel in first 3 gears. 150mph genuine .
  5. masterblader
    masterblader Active Member
    Found the 15t sprocket on a 530 chain caused more viabration the turning radius is much tighter, 15t on a
    525 chain is smoother. The standard gearing on the 04-05 is 16t front 40t rear
  6. kpone
    Newbie question here so I apologise beforehand, but does the speedo need recalibrating if you swap sprockets around?
  7. bluekontakt2004
    bluekontakt2004 Active Member
    -1 front +2 rear on my 05
  8. bluekontakt2004
    yes mate, you need a speedo healer.
  9. kpone
    Cheers Blue.
  10. bluekontakt2004
  11. Nutty Tart
    Nutty Tart Well-Known Member
    Yup thats me as well -1 +2 with a speedo healer
  12. exfire
    exfire Elite Member
    Thanks for all the replies so far, the most popular so far seems to be the -1 F + 2 R. Any problems with the 15 T sprocket running tigher over the smaller radiust causing vibration with a 530 chain like Bladerider mentioned ?
    Generally speaking, Is there a big difference between running a 525 chain as opposed to a 530 ?
    Writing this on Xmas morn at 4-30 am..........I must be mad..........no comments on that please :D
  13. megawatt
    Like Masterblader said, 15T 530 is a bit too small and can cause vibes and excessive wear. 525 is a bit lighter, sprockets a bit thinner. Not as strong as a 530, but I haven't bust a chain yet! This one has done 25,000 miles ! Wouldn't go to a 520 though! Can weigh my new 525 if ya want?:D
    #13 megawatt, Dec 25, 2011
  14. dan.1moore1
    for -1 +2 definitely need a speedo healer . I aint bothered for just -1 front as i think its roughly 7 to 10 mph
    FAO JM1 ......... Whats that web site you suggested before to work out how what gear changes affect your speedo ???
  15. masterblader
    1992 the blade had a 530 as standard in, 1996 with the RRT it went to a 525 which shaved off over 3lbs from the overall weight as big H were playing the power to weight game. In 2000 it went back to the 530 section for better mileage . Racing and TD boys settle for for the 520 section which is even lighter stronger and more expensive.
  16. exfire
    exfire Elite Member
    Merry Xmas, I am always amazed by how much knowlege is contained here by board members. You guys are impressive, it's like a motorcycle wickepedia only a lot better. Cheers.
  17. kpone
    Bikepedia.
  18. megawatt
    Masterblader is! He can bore for England.!!!
  19. gixerlc
    gixerlc Active Member
    following this with interest :D just trying to decide what to get for mine :D
  20. JM1
    JM1 Active Member
