Your doing good James, making steady progress.. Which Team Army are you in IG and where did you guy's finish, its great to see the army getting involved...
Yeah man really struggled with bad bad tyre wear on sat and sun was really getting me down couldn't stop the bike from sliding around. Ended up dropping to 22psi hot on the rear (pirelli superbike slick) and it finally stopped the taring and i could get the power down! Guess it was cos of the low temp someone said it was about 6 degrees. Anyway managed a 4th place from 13th on the grid and pb of 1.40. Wish i had sorted the tyre wear out when it was warmer as would of got into the 30s. Mint way to end the season tho. Cheers guys
Pics are up of the track day on Alex James Photography web site. There's a few pics of me (red R6, black leathers, white helmet) between James Ellison and his brother on Phil Seatons R1 around image 8819. I might be buying a few http://www.alexjamesphoto.com/eventsshoots/0810-donington/?sub=e2934bd114cb2b0b2aa6daed62721ba5
It's been an expensive year already! I've still got the standard shock in it and still have the CAT fitted. My bank balance will only get worse
