Original Exhaust Install
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolSam, Oct 17, 2015.
  1. RepsolSam
    RepsolSam Well-Known Member
    Looking to remove my Leo Vince can and buy and get a standard system on.
    Think I may have asked this..but can't find or remember..
    So I have found a can for £35.
    Does this need a link pipe also?
    Also what about the sensor? As I don't have this in place on the Leo Vince link pipes..
    Any other parts needed.
    Thanks
  2. carter
    carter New Member
    Link pipe no as its one unit with the ten tonne box on but the sensor yes
  3. Slick
    no link pipe needed.
    Ask the seller if the link gasket is still resuable, if not you will need a new one. Also check the exhaust band is in good condition, mine just fell off when I fitted my yoshi.
    It may be cheaper (and easier) not to bother with the sensor, just keep the o2 eliminator in place and bung the hole. I can imagine rerouting the sensor to be a right PITA if not you can buy this
    http://www.ebay.co.uk/itm/Honda-CBR...hash=item1ea0dcde37:m:mwI4Lqw0yfuVlVabMSvT58A.
    Not sure how the exhaust flapper has been disabled but you may have a servo buddy in there, if the servo is still there reattachment of the servo cable is pretty straight forward
  4. RepsolSam
    Cool...well just bung the hole..
    The flapper stuff is not in the bike..maybe removed by the last owner as there are no vacuum hoses at the front under the light etc..
  5. RepsolSam
    Going to collect now...
  6. RepsolSam
    Okay...why is it so difficult to get the pipe in..?
    Inside of the pipe on the exhaust end is getting in the way..
    Guessing its the gasket?
    Do i need a gasket?
    also clamp was all seized and i could not get it loose..so need a new clamp as well..
    bummer - sunday so will have to wait till next week
    #6 RepsolSam, Oct 17, 2015
  7. RepsolSam
  8. exuptoy
    exuptoy Elite Member
    No, it is a carbon black wound wire tube which slots into the pipe.
  9. RepsolSam
    okay, i had to take it out and came out not in one piece ..does it need replacing?
    as the leo vince link pipe did not have anything like this in it?
  10. exuptoy
    Yeah or it will not seal. The LV was an interference fit.
  11. RepsolSam
    Any ide aof costs? also need a clamp.
    What is this wire coming out of the exhaust..? were does this go
  12. exuptoy
    If you have the servo under the seat then it goes around the servo actuator and is connected to a flap in the exhaust which opens around 4k. The flapper mod is basically disconnecting it from the servo. Just tuck it up inside the seat subframe out of the way. The flap is sprung to fail open.
  13. iang27
    iang27 Active Member
    When I refitted my standard exhaust on my 13 plate I am sure it was a tight fit.
    I cannot remember if I fitted the gasket onto the down pipe first before pushing the silencer on, use a bit lube.
    The cable will be for the valve under the seat. It routes up behind the footrest.
    The motor is under a plastic panel, you can see it above the hugger if you look up, it has three plastic screws I think.
  14. Voleracing
    Voleracing Active Member
    Hi sam the wire is a power band that connects to turbo :p
    Youtube is your Friend
    Loads of other videos ABS model etc take your pick :cool:
  15. carter
    carter New Member
    Don't bother connecting the flap cable to the servo... not needed at all so wouldn't waste my time with it
  16. RepsolSam
    Cool..will leave it off..
    just need the gasket...or maybe not, but wont really know till i got the clamp on... need a clamp!
  17. And7rp2
    And7rp2 Elite Member
    a bit dodgy....... but if giving to a dealer, you don't really need the clamp
    ran one of my blades for months without one
  18. thezipsteruk
    thezipsteruk Elite Member
    ahh come on dude!
    at least post a forum members youtube rofl!
  19. Voleracing
    ^^^^ welcome to zippysword :)
  20. Ian E
    Ian E Active Member
