Datatool Alarm - issue
Discussion in 'General 1000RR Discussion' started by colly, Oct 17, 2015.
  1. colly
    colly Active Member
    I have a datatool alarm on my bike. It's annoying the hell out of me sometimes as if I forget to turn it off before I turn the key, the alarm goes off and usually take 20-30 seconds or more until I can get it to stop. I'm not sure what I'm supposed to be doing, I spend the 30 seoncds pushing the button, holding it, pressing it rapidly. It turns off eventually but not sure why.
    Today it went off, I managed to turn it off, but when I turned the key it went off again, that happened 3 times. I left it for 5 mins and it was fine.
    The beep is the same for arming and disarming which has cuased me to get it wrong in the past.
    Does anyone know the correct procedure for turning it off?
  2. kev.b
    kev.b Well-Known Member
    Best thing to do with all alarms is to remove it then bin it , And buy a proper chain . :)
    • Agree Agree x 3
  3. gixxerjim
    gixxerjim Active Member
    Yes kevs right
  4. colly
    colly Active Member
    So I just bought a tracker, getting it fitted soon. I already have a pretty good lock and getting an anchor put in.
    You reckon strip it out? Is the HISS enough?
    In the meantime, does anyone know how to disengage when it does go off?
  5. Dave
    Dave Member
    Had terrible trouble with a Datatool alarm/immobiliser on the Bimota:mad:, eventually removed the thing;).
  6. exuptoy
    exuptoy Elite Member
    I had to have a Thatcham cat 1 approved alarm to get insurance. Mine is a Meta 357T V2.1.
    #6 exuptoy, Oct 18, 2015
  7. madmac
    madmac Well-Known Member
    Not sure about modern Datatool alarms, but the Datatool S3 on my old bike had different beeps for arming/disarming (1 beep and 2 beeps) so not sure why yours sounds the same for both?? Which Datatool system is it you have?
