Storage condensation
Discussion in 'General 1000RR Discussion' started by steve750, Nov 2, 2015.
  1. steve750
    steve750 Active Member
    Is there anything to protect apart from using a heater?
  2. graemewalker
    graemewalker Elite Member
    Vacuum pack bag for bike
  3. sp1n99
    sp1n99 Active Member
    You could use a dehumidifier.
  4. MPJ
    MPJ Active Member
    Dehumidifier. I've used one for over 10 years. Big double garage (brick with timber roof) two classic cars and the bike in. Ebac industrial unit (due to garage size) works a treat, pulls loads of water out.
  5. sp1n99
    image.jpeg Or one of these from demon tweeks
  6. honda.ima
    honda.ima Active Member
    Frost guard heater and dehumidifier set to low keeps my humidity at about 60%.
  7. MPJ
    MPJ Active Member
    Those are great, my friend keeps a car in one. But they do use a fan to suck in air then blow it through the bubble, so if your garage is damp then it blows that damp air into the bubble so you need a dehumidifier as well.
  8. sp1n99
    Q: Does the Carcoon constantly blow large volumes of air into the bubble?
    A: The Carcoon has two modes of operation; the first is the initial drying mode, where maximum airflow across a warm vehicle removes all the moisture. This establishes a dry car in a dry environment. The essential drying mode is followed by the equally important storage mode: here, airflow from the ambient environment is effectively blocked by the super atmospheric, re-circulating airflow through the Activated Carbon filters. Such filters are fitted on the inside of the two air treatment units.
  9. MPJ
    MPJ Active Member
    I would guess they have changed the design then, plenty of early Porsche 911 guys on DDK forum use them with dehumidifiers. My friend keep his 67 show Beetle in his, the Speedwell mag wheels are worth more than a brand new blade.
  10. MrB
    MrB God Like
  11. MPJ
    MPJ Active Member
    MrB is your garage dry ?
  12. sp1n99
    I've known about Carcoon for years (but never owned one, never needed one) and have always understood that the car/ bike stood in a dry, recirculated air, otherwise you would be speeding up the rusting process.
  13. MrB
    MrB God Like
    Being timber it was quite dry (since moved) but far from 100%. The Carcoon kept the car bone dry could even put the car inside after being in the rain, open the zip and within a few hours it would be dry. Do the zip up and forget about it. Brilliant. I would replace the filters every 12 months and kept a wireless Hygrometer in there to measure the humidity.
    [​IMG]Carcoon storage system by (MrB), on Flickr
    #13 MrB, Nov 2, 2015
  14. neil.marsh.758
    neil.marsh.758 New Member
    Ive just put my blade in the Carcoon. They are based only down the road from me so I thought I would give one a try. I originally bought it to put my rd in but I've left that at my mates. They seem to get good reviews and it comes with a charger to keep the battery on the bike topped up over winter, if their is a power cut it then runs off the battery off the bike until the power comes back on, then it recharges the battery.
  15. t0m541
    t0m541 Senior Member
    Just bring it indoors, living room preferably, or if living in a bungalow, the master bedroom
  16. MrB
    MrB God Like
    Tis what I do now
    [​IMG]Untitled by (MrB), on Flickr
  17. Remal
    I love the carcoon but Will have to do with the Dehumidifier I've had on timer to remove the Condensations I sometimes get in the garage
