better than sliced bread
Discussion in 'Parts, Accessories & Clothing' started by okeloon, Nov 18, 2015.
  1. okeloon
    okeloon Active Member
    I'm the first to admit it, I'm a bit ancient (Rossi+1 as i like to say...47 to you), and only just stumbled on pinlock visors...OMG how long have these been available?
    No more holding your breath to stop the visor fogging up, or breathing through your nose, effin amazing!
    No need to rub lemon juice or to cut a spud in half and rub on the inside of my visor. What a god send!
    Ecstatic rant over.
  2. FirebladeRR
    FirebladeRR Active Member
    Btw Surely you mean 37?
  3. okeloon
    I wish...meant his race number + 1 ;)
  4. FirebladeRR
    Ahhhhh gotcha :rolleyes::cool:
  5. Lozzy
    Lol 47 ain't ancient :eek: ...If it is then I must be prehistoric :D
    Can't believe you've only just found pinlocks, I've got them in all my visors they're ace :)
  6. GappySmeg
    GappySmeg Well-Known Member
    I was a bit slow to cotton on to Pinlock too... was using "FogTech" wipes for years, which although very good, cannot beat Pinlock.
  7. SimonRR
    SimonRR God Like
    Yeah I have been using a while now, work very well :)
  8. Slick
    then you wont know about the Progrip version.
    Fog free and darkens in sunlight!!
    Stuck on rather than the pins so zero chance of moisture entering between the visor and insert.
  9. okeloon
    oooh you're right, didn't know about them either. cheers fella
  10. And7rp2
    And7rp2 Elite Member
    pinlock do transition version too
  11. bash1k
    bash1k Active Member
    Yeah pinlocks are dreamy...
  12. Barstewardsquad
    Love pinlocks, just wish they made them for specs.
  13. Nytol
    Nytol Active Member
    Do you have a link of where to buy these?
    I didn't like the pinlock on my Shark helmet so binned it, a replacement would be good.
  14. sp1n99
    sp1n99 Active Member
    When Pinlocks first came out no visors had the posts fitted. You had a kit that consisted of a drill bit and some concentric posts. You lined up the Pinlock, mark it then drilled. The concentric posts then took up any slack. I would imagine you could still get such kits so don't bin good helmets or visors because they haven't got the posts fitted.
    Of course that should be eccentric not concentric.
    #14 sp1n99, Nov 19, 2015
  15. Slick
    I'm mistaken they're Fine Vision inserts (made by Pinlock I believe) The are stuck down and have cut outs to accommodate failed pins
    see here for my review http://www.1000rr.co.uk/threads/new-pinlock-insert.14447/#post-227238
    feck me just checked the price less than £6 including postage!! the Pinlock equivalent is much more pricier
  16. kpone
    I've got scar tissue older than you...
  17. SteB
    SteB Member
    They do, they're called contact lenses, I changed to them a few months ago as I saw the benefit of Pinlock in the lid and then it was only the specs that fogged. Bin the specs and everything becomes clear.... :p
  18. sp1n99
    Inter-ocular lense replacement even better....but a bit expensive!
  19. SteB
    SteB Member
    I was going to do the whole laser thing but then I watched how it was done and it made me feel sick......
  20. Lozzy
    Still time to drop a hint to Mrs B for your Xmas stocking :D
