PC V5 map
Discussion in 'Maintenance' started by Great Guy, Dec 5, 2015.
  1. Great Guy
    Great Guy Well-Known Member
    Just been on the relevant site to download a map for my 2008 CBR1000RR.
    It has stock everything. However, the only map I can find is
    M19-002-001.pvm 2009 Honda CBR1000RR Stock exhaust and air filter.
    I am correct in assuming this will do.
    My 2008 looks the same as the 2009 one.
  2. Slick
    for OEM set up the map should be M16-002-501, not sure what the M19 maps are?
    M16-001 maps are CBR1000rr 09+,
    M16-001-0XX are US,
    M16-001-5XX are euro
    HTH
  3. Great Guy
    I will look. Thanks
  4. Great Guy
    I may of made a mistake. However, M16-002-501 REQUIRES Dynojet o2 eliminator.
    I think I need M16 -002-001... STOCK EVERYTHING. Is this correct?
  5. Slick
    You need an eliminator withthe PCV, it will not work properly without one.
    Without it the PCV and ECU will 'fight' each other in closed loop fuelling
  6. Great Guy
    Where do you get this thing from? Should you not of sold yours with it ?
  7. Slick
  8. Great Guy
  9. ShinySideUp
    ShinySideUp Elite Member
  10. Stevie_d
    Stevie_d Senior Member
    Why on earth do you need a power commander with maps if the bike is totally stock ?
  11. Mr OCD
    Mr OCD Well-Known Member
    ... Because the fueling at low throttle openings is poor.
    ... Because they run lean as standard
    ... Because you gain more power with an enriched map.
  12. steve750
    steve750 Active Member
    As Mr OCD just said. The enrichment factor at especially low throttle increments is ironed out with the aid of the PC5.
  13. Mr OCD
    I'm actually running my 2010 blade standard at the moment with PC5 ... :)
  14. Great Guy
    Does this mean ;you have not put an 02 eliminator in/on. I thought a fireblade has one on by default anyway.
    Does the pc make any difference?
  15. Great Guy
    Because I am cool. And I can. One does not walk up mountains for exercise, you walk up because they are there.
    #15 Great Guy, Dec 6, 2015
  16. Mr OCD
    I have an O2 eliminator fitted of course.
    Yes, it makes a difference.
  17. Great Guy
    Is it the OEM Honda one, that is already attached to underside of the exhaust?
    #17 Great Guy, Dec 6, 2015
  18. Mr OCD
    No such thing! The bike comes with an O2 sensor as standard. An eliminator removes the sensor.
    There is no point running a PCV with the O2 sensor plug in... It needs to be removed.
  19. Great Guy
    I see. Thanks.
  20. Stevie_d
    Interesting , I thought a stock was supposed to be fine and only needed pc v with a non standard pipe , air filter etc etc
