Heated(Oxford) grips.
Discussion in 'Maintenance' started by Great Guy, Nov 26, 2015.
  1. Great Guy
    Great Guy Well-Known Member
    Having some fitted tomorrow . As I ride on cold DRY days through the Winter. Do they do keep your hands nice and warm? I am sick of bending down a holding the crank case as I am riding along! Anybody else use these?
    #1 Great Guy, Nov 26, 2015
  2. kpone
    I've had them and they do warm up your palms really well. My problem is encroaching arthritis in my knuckles though and I was surprised that it took some time for th warmth to leech through, but I suppose it was the airflow causing this quirk. But I will say they contributed really well to keeping me out in the winter.
  3. Nytol
    Nytol Active Member
    I have some fitted to my other bike and find them to be excellent, the highest setting is uncomfortably warm.
    I was trying to avoid changing the grips on the blade, as I like them, but after a few days this week, I may have to concede to the weather.
  4. Nickw
    Nickw Active Member
    I had them fitted on my blade last week.... Oooooh Yes!
  5. Geoff Paxton
    Geoff Paxton Member
  6. Great Guy
    Going with Oxford because local Honda dealer only fits these. Plus they are discounting at present. They said " they don't rate data tool gear."
  7. Slick
    The Blade is the first bike I've had without heated grips( my gloves are very good!!) , but had both Oxford and Honda on (naked) previous bike. Honda grips are just plain awesome, Oxford OK but wires started to degrade within a year.
  8. Great Guy
    image.jpeg image.jpeg Job done. Superb and wired into the ignition.
    #8 Great Guy, Nov 27, 2015
  9. Nickw
    Nickw Active Member
  10. sinewave
    Toasty!
  11. Great Guy
    Very good
  12. travellingkiwi
    travellingkiwi Active Member
    I have Honda heated grips. Fitted at purchase. They're great with the button in the grip itself. The only issue I really have is the screw came out after 2 years and it's currently held together by insulation tape..
    Those Datatools look nice too... A slightly better switch than the Honda (Direct versus the Honda push to toggle between 3 heats and off which requires you to take your eyes off the road to check what they're set to).
    I didn't really like the Oxford. Although I've had them several times, the separate control looks a bit ugly IMO...
    H
  13. Great Guy
    I did not like them from pics on the Internet. However; after having them fitted and using them, I can only say "brilliant." They look and feel good and I will have them fitted on my next blade in 2017.
  14. Punisher5964
    Punisher5964 Active Member
    Mine came with them fitted and I was going to remove them but actually there great, a couple of times I've been riding with freezing hands and then remember they're there. highest setting is like gripping lava though!
  15. Andrew Penson
    Andrew Penson Member
    Tried mine last weekend, set at 20% and they were toasty. A must for all my future road bikes !!!
  16. jpsrepsol
    jpsrepsol Active Member
    I tried to order some of these direct from datatool and was told they don't make them anymore as they kept getting faults with the thumb slider just a heads up
  17. jpsrepsol
  18. Nytol
    Nytol Active Member
    I had a new set of Oxfords fitted when the KLV went in for some TLC, and 50% was too warm :D
  19. stevet
    stevet Active Member
    why did i wait 8 year to fit oxford heated grips
  20. Lozzy
    Jeez guys....what's all this warm hands stuff o_O
    Takes the fun out of warming your chilly bits on your beloved when you get back :D
