Stone killed my radiator! edit failure was caused by the small fan!!
Discussion in 'General 1000RR Discussion' started by Slick, Jan 7, 2016.
  1. Slick
    I normally have either a rad guard or fenda extender.
    Only ran the blade without them for 2 months or so and bam, a stone right through the rad. Coolant spewing everywhere and a duff rad.
    Lesson learnt:(
    Luckily I have a spare radiator in the shed, being fitted tomorrow!:D
    #1 Slick, Jan 7, 2016
  2. sinewave
    Every new Bike I buy never turns a wheel till it's gota Rad Guard on.
    Bike Rads aint cheap!
  3. RR_mike
    RR_mike New Member
    Dam that really sucks. I better look into getting one.
  4. Jimbo Vills
    Put a bullet hole through my bro's bike.... was bad! luckily we had the scals on and Dave could warn him from behind as coolant pissing all over the bike at not so "hanging around" speeds....
    Got new rad now but not a cheap fix!! always put a guard on mine....
  5. Slick
    Luckily bought a spare a while back, irony is I have 2 rad guards sat in the shed and a fenda extenda, since my crash I hadn't bothered refitting...... doh!
  6. Philp10
    Philp10 Member
    Hiya. How easy r they to fit. Do u have to take the fairings off any drilling etc.
  7. Slick
    Not sure about rr12+, but rr8 are only to remove the lower rad bolt, fit in the guard then replace bolt and zip tie the top. No drilling or fairing removal. ABS slightly more fiddly to fit due to extra plumbing.
    The fenda extenda, IMO is essential on a road bike (up to you if you wish to use with rad guard) as it will reduce the amount of crud build up on the rad. This does require drilling of the front mud guard.
  8. Philp10
    Philp10 Member
    Thanks slick. As I am off to the tt this year might invest.
  9. sp1n99
    sp1n99 Active Member
    I've used Sikaflex 291i (a marine adhesive) to fix fenda extenda's in the past. It works well and even fills the inevitable gap between the extenda and MUDGUARD ( not fender) lol.
    A tip if you go this route is to run some tank tape along the extenda before applying the adhesive so that the tape takes the weight off the extenda while the adhesive cures (about 24 hours).
  10. Slick
    probs be selling off the old radiator as scrap/repairable, maybe £30-40 to cover postage and my gym membership!
    shout for first dibs!
  11. Slick
    Found the culprit, my recent crash bent the left fan causing it to slightly touch the radiator wearing the core.
    It's a minute hole easy fix for someone in the know.
  12. Glb
    Glb Active Member
    Mine did exactly the second thing. Got it repaired and now it's bang on
  13. Glb
    Glb Active Member
    Also spaced the fan off with some washers so it won't do it again
  14. ShinySideUp
    ShinySideUp Elite Member
    The hole in the cross bar could possibly be fixed by some solder and a soldering iron/small gas blow torch! ;)
  15. Slick
    I might just try that!, any tips on how to pressure check it afterwards?
  16. Dave
    Dave Member
    Unlikely that you'll be able to solder that as rads are all Aluminium now, TIG welding job;)
  17. ShinySideUp
    The one in the pic above looks like standard steel sides with copper cross bars to me mate. :)
  18. Scott
    Scott Active Member
    Got a spare fan if u need one
  19. Dave
    Dave Member
    Don't think you'll find many radiator manufacturers using copper:eek: in the manufacturing process, to expensive.
  20. Slick
    Thanks for the offer, but got spare fans hanging in the shed too!
